It is currently Wed Jan 23, 2019 8:25 am
 Post subject: Rear wheel cylinders
PostPosted: Wed May 19, 2010 7:04 pm
I need to replace one of the rear cylinders (I'll do both). RockAuto lists a bunch that are less than $10 including an ACDelco part. Then there's another ACDelco part that is $60 (GM part number 18060172). Do I need that one since it's the only one that says ABS in the description or can I use one of the others?
 Post subject: Re: Rear wheel cylinders
PostPosted: Wed May 19, 2010 8:56 pm
Year and Trim: ____
ABS makes no difference for them
If they still have the super cheap Wagner ones, get those, I did, was like $12 shipped, and they work great! They're of excellent quality.
John
PostPosted: Wed May 19, 2010 11:51 pm
Senior Moderator
Senior Moderator
Year and Trim: 00' SSEi
I did both my rears about 4 years ago with cheap Wagners, worked great, still work awesome. No ABS problems at all
2016 GMC Sierra 1500 All Terrain. 5.3L 8speed
2000 Bonneville SSEi.
PostPosted: Thu May 20, 2010 9:53 am
I ordered the ACDelcos that were the same price.
There are no new unread posts for this topic. Rear Wheel Brake Cylinders leak
1oldman
Fri Nov 12, 2010 12:39 pm
There are no new unread posts for this topic. questions on changing rear wheel cylinders
95se
Mon Nov 11, 2013 7:55 pm
95se View the latest post
There are no new unread posts for this topic. rear wheel bearing.
hall1971na
Mon Nov 28, 2011 10:31 am
hall1971na View the latest post
There are no new unread posts for this topic. Rear Tire/Wheel/Hub Problem?
jpp355
20
3757
Mon Jul 07, 2008 6:25 pm
jpp355 View the latest post
There are no new unread posts for this topic. Passenger rear wheel is locked up.
Boreas
Sat Sep 24, 2011 8:20 pm
