It is currently Mon Jan 21, 2019 8:01 am
 Post subject: Check engine light
PostPosted: Sat Apr 03, 2010 1:09 pm
Year and Trim: Back on deck... White 94 SSEi..
My Connector is shaped like this \______/...Is that OBD I or II?
Back on deck with a 94 SSEi... 294K and counting!Image
 Post subject: Re: Check engine light
PostPosted: Sat Apr 03, 2010 1:12 pm
You have OBD 1.5, basically OBD I hooked through an OBD II connector. 96 was the first year Bonnevilles had OBD II.
PostPosted: Sat Apr 03, 2010 2:17 pm
So when I go to O'reilys I need an OBD I scanner with the OBD II Connector....
PostPosted: Sat Apr 03, 2010 4:01 pm
Yes, or an OBD2 scanner that can read OBD1 codes. But with an OBD2 connector.
PostPosted: Sat Aug 07, 2010 4:31 pm
Year and Trim: 1995 Bonneville SSEI 3800 Supercharged V6
So that's why the OBD II scanner I bought just sits there and says "NO LINK" and nothing else...stupid 1995 SSEi! :angry4:
Dutch
1995 Bonneville SSEI Supercharged V6 3800 (195,000 miles)
PostPosted: Sat Aug 07, 2010 4:40 pm
Unfortunately.
PostPosted: Sat Aug 07, 2010 4:54 pm
So in other words (to make sure I understand)...I have to buy an OBD I scanner, but have to find cables/connectors that will hook up into the OBD II connector I have under my dash...craziness!
I noticed that the pins on the OBD II scanner connector do not match the "sockets" perfectly on my under-dash connector. Hmmmmmmmm? :ack:
Or just sell the darn car as is or for parts...
Dutch
There are no new unread posts for this topic. Check engine light.
MStokes
Fri Mar 13, 2009 7:04 pm
sandrock View the latest post
There are no new unread posts for this topic. Check Engine Light
Rapp16
17
3382
Mon Dec 20, 2010 12:42 am
Rapp16 View the latest post
There are no new unread posts for this topic. Resetting check engine light
Blue_Bonne
Tue Oct 19, 2010 12:18 am
comatoast View the latest post
There are no new unread posts for this topic. Check Engine Light Bulb Out?
ozman2988
Wed May 18, 2016 10:06 am
ozman2988 View the latest post
There are no new unread posts for this topic. Help needed with Check Engine light and code
Bigerik
Mon Jul 21, 2008 8:50 pm
Bigerik View the latest post
cron
