It is currently Wed Feb 26, 2020 1:05 pm
PostPosted: Sat Feb 13, 2010 12:44 pm
Year and Trim: 1996 Bonneville se
How do I replace it??? 1995 Bonneville SE. Thanks
PostPosted: Sat Feb 13, 2010 1:41 pm
I searched this site for "change heater core" and found this thread (among others):
viewtopic.php?f=19&t=1516&hilit=change+heater+core
1998 3.8 Dodge Caravan 214K
2000 3.3 Dodge Caravan 175K
PostPosted: Sat Feb 13, 2010 2:30 pm
Thanks
PostPosted: Sun Feb 14, 2010 12:22 pm
If you replace those stupid hose clamps (what are those called again, Bill? I forget) with traditional geared clamps the job will go much easier.
Also, it's hard to remove the heater core clamps at the firewall because they're down low and fairly inaccessible. Just break them off (they're plastic) with a long screwdriver and you'll save yourself quite a bit of time.
Don't forget to vaseline both the inside of the hose and the nipples on the new heater core so the new hoses slip on easily.
PostPosted: Sun Feb 14, 2010 3:41 pm
I finished it in about 2.5 hours yesterday. Thanks guy's. I used axle grease on the hose and put two new hose's on while I was at it. I borrowed a pair of Mac hose clamp pliers from a friend to get the old ones off with and put standard gear type back on it. Those plier's with the cable on them are the stuff. I've used them alot and they are an invaluable tool. Thanks for the help.
There are no new unread posts for this topic. Heater core replacement on the '93
crash93ssei
Thu Sep 25, 2008 10:35 pm
Pontiac1 View the latest post
There are no new unread posts for this topic. Heater core replacement - Remove the dash? Really?
NotDadsW41
11
5769
Sat May 12, 2012 8:54 am
There are no new unread posts for this topic. more detailed instructions on heater core replacement?
Need For Steve
Sun Jan 20, 2013 3:55 pm
Need For Steve View the latest post
There are no new unread posts for this topic. heater core
xvr843
Sat Nov 05, 2011 9:03 am
There are no new unread posts for this topic. Heater core question
92BonnevilleSE
Tue May 05, 2009 12:28 am
92BonnevilleSE View the latest post
Users browsing this forum: Google [Bot] and 6 guests
