It is currently Mon Jan 21, 2019 9:44 am
PostPosted: Mon Feb 01, 2010 9:41 am
Year and Trim: 1993 Bonneville SE, restoration finished
This is starting to act up on my '99 olds eighty eight. No, it is not the key circuit, the module itself is intermittent. I have the correct resistor spliced in place near the module, still having the same issue. I've seen on the internet the homemade bypass modules that duplicate the pulse the fuel enable circuit needs to see (as well as the ground for the starter enable) but I want to hear from someone who has built and installed one successfully. Thanks. Mike
1993 SE with SLE appearance package. Factory stock except for steering wheel buttons, AM/FM/CD from a '93SSEi and chrome wheels.
1999 Olds Eighty-Eight LS Anniversary Edition, my daily driver.
2004 Chrysler Minivan, wife's daily driver.
PostPosted: Mon Feb 01, 2010 3:39 pm
I will be a tad off topic here... But if you know anyone with an HP tuner, DHP or a Tech 2 you should be able to disable security and never have to deal with the issue again.. Just a thought
PostPosted: Mon Feb 01, 2010 3:51 pm
Just a thought? A pretty awesome thought actually... too bad I don't know anyone!! dangit.
PostPosted: Mon Feb 01, 2010 4:12 pm
I believe on the 99 PCM you can have VTD Disabled in the PCM.. Its not hard to do.. Just have to have that special person with a tuner...lol
Both myself and a local have had to turn the VTD( Security ) off for the vehicle to start and run... For me I didn't have security to begin with and his system would not function with the newer PCM he used.. So we simply turn it off..
There are no new unread posts for this topic. Passkey System Issues.
RJolly87
Sun May 24, 2009 4:29 pm
RJolly87 View the latest post
There are no new unread posts for this topic. Security light still on after VATS bypass
Jfridge92
Mon Aug 08, 2016 3:22 pm
There are no new unread posts for this topic. OEM Security system ?
TDS-94SSEi
Thu Jun 21, 2012 4:49 pm
TDS-94SSEi View the latest post
There are no new unread posts for this topic. Help! Security system gone haywire!
rjwil
Wed Oct 21, 2009 12:27 pm
mntnbkr View the latest post
There are no new unread posts for this topic. Car runs great, when it runs...possible security system prob
hobbie2k
24
5117
Sat Feb 04, 2012 4:14 am
