It is currently Fri Feb 15, 2019 5:12 pm
 Post subject: 1996 Heater
PostPosted: Fri Jan 22, 2010 9:41 am
Year and Trim: 96 and 98 Bonneville SSEI
I have a 1996 Bonneville that has a heating problem. The heat does work but only
sometimes. The heat will work initially but will go cold occasionally. It will return to heat if the car is turned off and
started again. Unless I replace the entire system, I'm unable to get a mechanic to narrow the problem down. Any
suggestions?
 Post subject: Re: 1996 Heater
PostPosted: Fri Jan 22, 2010 10:19 am
Is this an airmix actuator problem? I've never had this issue, but it sounds like the issue to me.
PostPosted: Fri Jan 22, 2010 10:53 am
yeah, it sounds like a leaking climate control vacuum system. I would think that is the only thing it could be. if hot water is getting to the core then the only thing that would stop warm air from getting to the vents would be a closing air duct door.
I have warmer air flowing out some vents than others. It's tough to get around in there to check things out. taking the dash off is recommended, but that doesn't seem worth the hassle in my case. You can get at the actuators on the passenger side by taking apart the glove box. And you can pull the climate control nob panel to check vac tubing connections there.
great car. Wrecked
Burnt Bonny.
PostPosted: Fri Jan 22, 2010 11:48 am
Check things in this order: Coolant level in the radiator with the engine cold. Low coolant can starve the heater core of coolant causing intermittent heat. Next, check heater hoses with engine warmed up. Both should be hot, top hose just a little warmer. If the lower (return) hose is a lot cooler that the feed hose, suspect a blocked heater core. If both hoses are hot, and heater is not blowing hot air, then the problem is in the ducts - usually a bad airmix door actuator. Air not blowing where it should suggests vacuum problems with air-duct flap acutators (vacuum motors.)
Lots of information here if you use the "search" feature.
1998 3.8 Dodge Caravan 214K
2000 3.3 Dodge Caravan 175K
PostPosted: Fri Jan 22, 2010 12:16 pm
Year and Trim: before cars
Yes, as Bill said, check coolant level first. If that looks good, check everything else he listed in that exact order.
PostPosted: Fri Jan 22, 2010 2:00 pm
I'm not sure. I've never faced this either (or heard of an airmix actuator). Can you tell me what it involves to repair or where I might find it? Anything you can tell me would be more than I know...
PostPosted: Fri Jan 22, 2010 2:06 pm
Thanks all.
I'll start there and see what I can find out
Regards,
Dave
PostPosted: Fri Jan 22, 2010 2:08 pm
Here's our Techinfo article on the actuator.
viewtopic.php?f=49&t=3537
PostPosted: Wed Jan 27, 2010 1:36 pm
Year and Trim: 1991 SSE+I. 1994 ssei
sounds exactly like what my 96 did and the airmix actuator was the culprit.
1991 SSE+I ( supercharged)
1994 ssei
WCBF '08
There are no new unread posts for this topic. 1996 AC/heater blower motor cover?
ottismyman
Sat Mar 08, 2014 3:15 pm
bjstorm69 View the latest post
There are no new unread posts for this topic. AC/Heater fan
psomers
Wed Sep 17, 2014 6:26 pm
psomers View the latest post
There are no new unread posts for this topic. AC/Heater fan will not cut off
psomers
Wed Jun 04, 2014 1:26 pm
There are no new unread posts for this topic. heater box
xvr843
Tue Jun 14, 2011 10:32 pm
xvr843 View the latest post
There are no new unread posts for this topic. How Hot should your heater be????
bjstorm69
12
1345
Mon Mar 10, 2014 10:12 am
