It is currently Tue Apr 16, 2024 1:59 pm
PostPosted: Thu Jun 05, 2008 3:30 pm
Year and Trim: 03 SE
I have replaced the same coil (Top, I believe it is 1,3) twice in the past 6 months. Today again it failed. This will be the third one! What would cause this? Bad wires, plugs, ignition module? This is driving me nuts!! Wires are a year old as well as the plugs with about 8K on them.
13 Chevy Malibu LS 73K
The only dumb question is the one you didn't ask.
PostPosted: Thu Jun 05, 2008 4:47 pm
you can try to remove the icm and wire brush the bracket it mounts to. idk thats weird that that is the only coil failing.
yourgrandma wrote:
High
PostPosted: Thu Jun 05, 2008 7:25 pm
Well shame on me for jumping to conclusions before I inspect. All coils are fine. The problem is a cylinder 4 misfire and it is bad. At idle it's not too bad but trying to pick up speed from a stop it's running on 5 cylinders. It's not the wire, I checked that and even switched with another to see if it switched cylinders. I suspect fuel injector but I feel it pulsing. I'll check the plug. Hopefully it's not a dead cylinder. I'll search for help and if need to I'll post a new topic.
There are no new unread posts for this topic. Shudder in OD *updated* Ignition Coil Results
Honest Bob
12
3541
Wed Aug 04, 2010 7:16 am
1fatcat View the latest post
There are no new unread posts for this topic. Coil
Malachias
Wed Jul 30, 2014 12:30 am
J Wikoff View the latest post
There are no new unread posts for this topic. ignition coil
vdog313
Sat Jun 21, 2008 4:36 pm
vdog313 View the latest post
There are no new unread posts for this topic. All in one ignition coil or 3 individual
ARMT
Tue Nov 18, 2014 10:32 pm
There are no new unread posts for this topic. rear coil spring removal
grey3800
Mon Jun 13, 2011 10:17 am
grey3800 View the latest post
