It is currently Tue Apr 16, 2024 12:31 am
PostPosted: Sun Sep 27, 2009 9:37 pm
Year and Trim: 93 SE
I have a 93 SE with 163,000 miles that had been running great, transmission shifting smooth until yesterday. I had a transmission cooling hose leak yesterday. I pulled over and parked. Lost fluid but was able to repair leak. After fixing the leak, I put in about 4 quarts of generic replacement fluid for dexron III and mercon since you cannot buy dexron II anymore. Forgot when I put it in that I had put in Dexron VI when I changed fluid/filter about 25,000 miles ago. Noticed it started shifting hard when transmission would change gears. Changed fluid and filter today with 6.5 quarts new generic "dexmerc" fluid, which is supposed to be replacement for Dexron II/III. Still shifts hard when transmission changes gears. Anyone have any idea why and what I can do to make the shifting smoother?
PostPosted: Mon Sep 28, 2009 9:14 pm
Year and Trim: 96 SSEi- 157K
i don't imagine that you can truly reverse the problem without rebuilding, but i do know that i've had great luck with lucas trans fix and high mileage transmissions. it thickens up the fluid and tends to smooth out shifts and minimize slips. be sure to siphon some old fluid out of course.
- Rachael
PostPosted: Tue Sep 29, 2009 9:31 pm
Thanks. I'll have to try it. Anyone else want to weigh in??
PostPosted: Tue Sep 29, 2009 10:03 pm
I also like TransFix.
PostPosted: Tue Sep 29, 2009 11:49 pm
Year and Trim: before cars
Check the vacuum line going to the vacuum modulator valve for transmission fluid inside the line. There should be none. If there is any, replace the valve. Fluid in the line means the diaphram inside the valve is leaking.
There are no new unread posts for this topic. Hard Shifts
ijreed
Fri Mar 16, 2012 12:39 am
ijreed View the latest post
There are no new unread posts for this topic. Transmissoin Shifts Hard
ice_qube
Mon Jun 07, 2010 7:49 pm
ice_qube View the latest post
There are no new unread posts for this topic. Transmission shifts hard after changing vacuum modulator
Jonathan37355
Fri Nov 12, 2010 2:30 pm
There are no new unread posts for this topic. Tranny Fluid
Ragsdale
Mon Dec 08, 2008 8:25 pm
There are no new unread posts for this topic. Tranny Fluid Myth
jdronzek
22
5494
Wed Aug 19, 2009 7:27 pm
Ol' Timer View the latest post
