It is currently Fri Apr 26, 2019 10:20 am
PostPosted: Tue Sep 01, 2009 2:42 pm
Year and Trim: 2004 Volvo S60
I think my master cylinder is going. The car gets it's brakes bled annually, and after new brakes the car just doesn't feel as it should, it was my mechanics advice that the master cylinder might be the culprit in this. How can I check further? Also...I see there are numerous "size" master cylinders, what do I want/need?
PostPosted: Tue Sep 01, 2009 9:25 pm
How do the brakes feel now, causing concern?
And the size is determined by measuring the length of the unit, mounting flange excluded I believe. It is going to be obvious when you put a tape measure on it.
PostPosted: Tue Sep 01, 2009 9:44 pm
It was before, whenever I stopped at the very end of the stop where it's coming to 0, it would get very soft but that seems to have alleviated itself. It happened only after compressing the pistons on the calipers to install the new pads. Also, I have taken notice the sliders were frozen cause only the outer pads were worn down, not the inner. I have greased the sliders but will re-check in a week.
Before this, I had felt varying brake feel, like sometimes it would go down further on the pedal than others, but if the sliders for the calipers weren't working right....I guess that could cause a lot?
PostPosted: Tue Sep 01, 2009 9:51 pm
Moderator
Moderator
Year and Trim: 09 G8 GT
Yeah, I would be wary of the master cylinder. When mine went, it would only start losing pressure in one of two ways:
1.) Every dozen or so brake pedal presses
2.) Pedal would go to floor after holding brakes on for 5-10 seconds
#2 could be your symptom with the softness when coming to a stop.
PostPosted: Tue Sep 01, 2009 9:55 pm
It seemed consistent tonight after it's little episode, I'm gonna keep an eye on it, but I know it has a LOT of miles on it more than likely, so I might be changing it very soon....
PostPosted: Tue Sep 01, 2009 10:00 pm
Moderator
Moderator
There's also the dribble of brake fluid on the outside of the brake booster below the MC. I actually missed it the first time I was checking, fluid level looked good at the time and it was a small dribble.
PostPosted: Tue Sep 01, 2009 10:02 pm
I'll clean up tomorrow and take a look after, since today I compressed the pistons on the calipers there's fluid that leaked out of the tank so yeah, kinda hard to tell now. :roll:
PostPosted: Wed Sep 02, 2009 2:52 am
I was told my brakes could be suffering from a bad BMC, but my symptoms don't match.
I changed the brakes and 1 rotor on my friends van and when I compressed the caliper brake fluid squirted out the two tiny vent holes on the BMC cap.
great car. Wrecked
Burnt Bonny.
PostPosted: Wed Sep 02, 2009 7:53 am
That is normal when you compress the caliper, but I am surprised that you didn't replace both rotors. My master cylinder when it was going both times was indicated by a low and spongy pedal, even after bleeding and adjustment.
PostPosted: Wed Sep 02, 2009 8:58 am
Sometimes, master cylinders need to be replaced a few months after the front pads are changed. Here is one way that can happen, and how you can avoid it.
Heavy, abrasive contaminants collect in the brake fluid at the lowest point in the system, i.e., behind the caliper piston. When the caliper pistons are compressed to change the pads, this contaminated brake fluid is forced through the master cylinder into the reservoir. These contaminants can quickly damage the seals on the piston in the master cylinder causing the seals to leak and allowing the pedal to slowly drop to the floor when the brakes are applied.
To avoid this problem, open the bleeder screw on the caliper while compressing the caliper piston. The dirty fluid can thus be diverted to a pan, and the master cylinder will not overflow. If you are careful to only open the bleeder while pressure is being applied and to close it when the piston bottoms out before pressure is released, air will not be sucked into the line and bleeding will not be needed.
Periodic flushing of brake fluid will remove these contaminants and minimize the probability that you will suffer from this problem.
1998 3.8 Dodge Caravan 214K
2000 3.3 Dodge Caravan 175K
PostPosted: Wed Sep 02, 2009 5:13 pm
I usually flush annually, but I noticed the fluid is dirty. I may do a flush again and clean the system out well due to how much AMSOIL Dot 3 high performance fluid I have and it's low cost to me. The car is being very consistent now in braking, I am thinking it needs a flush....
PostPosted: Tue Jul 31, 2018 7:51 am
Year and Trim: 1998 pontiac bonneville se
Just curious my master cylinder went out and will be replacing it. Since air is in the system do I need to bleed the ABS system also? If so how do you do it?
There are no new unread posts for this topic. Bad master cylinder, or re-bleed needed? (new booster fixed)
LeSabre in Buffalo
40
3857
Tue Jul 31, 2018 7:41 am
wpbrink View the latest post
There are no new unread posts for this topic. Master cylinder. .. 99' Bonneville
wpbrink
Tue Jul 31, 2018 2:25 pm
95naSTA View the latest post
There are no new unread posts for this topic. Master cylinder change
bobfather99
Tue Jan 20, 2009 5:13 pm
Troyport View the latest post
There are no new unread posts for this topic. Brake Master Cylinder on a 94 SE
spoiledred94
Fri Jul 10, 2009 3:00 pm
There are no new unread posts for this topic. Master Cylinder question
mythicSSEi
Sun Nov 02, 2008 11:45 pm
willwren View the latest post
