It is currently Sat Mar 23, 2019 4:34 pm
PostPosted: Mon Jun 02, 2008 2:39 am
Year and Trim: 95 Park Ave (S/C)
98 Bonneville SE
I have a 94 Buick LeSabre that has a powertrain with 97k miles on it, the subframe on the car is completely rusted out and I have not found a 92-94 Bonneville to put the powertrain in. I found a nice 96 Bonneville that needs an engine, but low mileage Series II engines are a bit pricey in my area so I would like to know what all would need to be done to put my engine and tranny into the 96 Bonneville.
PostPosted: Mon Jun 02, 2008 6:43 am
Odd....most go the other way around :wink:
It could be done, but it is not plug-and-play. The engine harness will have to be completely redone from scratch as there were no factory offerings for the OBD2 computer AND a Series 1 motor. Even then, the PCM will need to be reflashed to effectively run the S1...fuel, spark, knock, and trans tables would be vastly different. And NOBODY has those custom tables yet...except for me, and even those are experimental at best.
BonneMe wrote:
PostPosted: Mon Jun 02, 2008 8:11 am
Swap the entire engine, trans, wiring harness, PCM, and axles. You'll need the factory manuals for both cars.
PostPosted: Mon Jun 02, 2008 8:25 am
However, VATS will still need to be dealt with. The truth is, no matter which direction you go, there is going to be alot of work involved. I'm not saying it can't be done, because I know it CAN be done. But, you have to consider the fact that you will be spending a good double or even triple the time in modifying the electrical system to accept the older drivetrain than you would if all you were doing was just swapping the engine with a new, proper powerplant.
PostPosted: Mon Jun 02, 2008 11:21 am
98 Bonneville SE
Thanks for the replys. I have had a few replys from guys that have engines for sale, one is a S2 out of a Grand Prix, the other is a S2 engine and trans out of a super charged 96 Bonneville. As far as the S2 out of the Grand Prix which years would be a simple swap?What all would need to be done to swap the powertrain from super charged 96 Bonneville?
The engines would be going into a non supercharged 96 Bonneville.
PostPosted: Mon Jun 02, 2008 11:30 am
The swap from a non supercharged series II to a supercharged series II requires the entire motor, pcm, and harness. For the highest probablility of success, take the entire driveline (engine, transmission, cradle, and wiring) from the donor vehicle and install it in the car as a unit. There are internal differences in supercharged series II motors that you would want, so it's more than just taking the top end. By the same token, the PCM is set up for the transmission's gear ratios, so it is best to treat the entire engine & transmission as a unit to be installed together.
From a mere "bolt it up" perspective. Any of the 3800 motors will fit if you are willing to track down all the parts (accessory drives, wiring harnesses, etc.)
Best way to do this: Find your donor car with the supercharged, series II L67 motor. Take all of it, including the cradle, transmission, etc. Get a service manual from the car the motor came from (mostly for the wiring diagrams.) It's better for you if the donor car was another H-body like your Bonneville...as there are differences in the mounting brackets in other platforms. If the donor is a different platform, then someone like Ed Morad can usually come up with the brackets you'll need to get the motor in the H-body properly. The rest is wiring..making sure all the body harness wiring is pinned to the L67 PCM in the proper connector and pin. From that point forward, you car has a split personallity: Any problems with the chassis, treat it like the car it is. Any problems with the driveline, treat it like the donor vehicle the powertrain came from.
PostPosted: Tue Jun 03, 2008 8:14 am
Senior Moderator
Senior Moderator
Year and Trim: _
Moved to 92-99.
There are no new unread posts for this topic. series I engine leaks & repairs (engine oil cooler hoses)
aukc
Sun Apr 30, 2017 8:16 pm
PavliCZek View the latest post
There are no new unread posts for this topic. will a 95 series 1 alt fit a 95 series ll engine.
88bonnsse
Wed Sep 17, 2008 1:34 pm
bonnevillain View the latest post
There are no new unread posts for this topic. Retrofit HUD to non-equipped car 1995?
forg0tmypen
Wed Mar 13, 2013 9:43 am
There are no new unread posts for this topic. new engine, series 1 or 2
coop8070
14
971
Sat Apr 19, 2014 12:58 am
RJolly87 View the latest post
There are no new unread posts for this topic. What Series engine
londonontman
Sat Oct 31, 2009 12:49 pm
J Wikoff View the latest post
Users browsing this forum: No registered users and 19 guests
