It is currently Tue Jul 14, 2020 3:18 pm
PostPosted: Tue Aug 25, 2009 11:36 am
Year and Trim: 99 SL
While driving along car will just quit for a second and continue on. Sometimes the chime will sound and sometimes not. This happens maybe once every 3 or 4 days. In the past, the car has just shutdown at highway speed and I would put it in neutral and it would start right up. The VATS has been bypassed by the way. I am thinking ECM as there is no check engine light. Does anyone have any thoughts on this?
PostPosted: Tue Aug 25, 2009 12:09 pm
Year and Trim: 2004 Volvo S60
When you say shutdown, does the entire car's power die also or just the motor?
Reason being is, I had my car turn completely off once and then it started back up, turned out battery terminals were corroded.
PostPosted: Tue Aug 25, 2009 12:28 pm
This was caused by a bad PCM on my 95.. but the 95's are known for having flaky PCMs, and i wouldn't think it's as likely on a 99. Sounds exactly like what I had though. You could also check all of your ground points, and battery cables.
PostPosted: Tue Aug 25, 2009 12:36 pm
Year and Trim: 1999 SSEi
1997 SSEi-Resting-353K
the list of causes is long. The fix for my 97 with this condition was fuel pump. Another recent case tried the fuel pump and was unsuccessful. Could be fuel pressure regulator, crank sensor, bad battery connections, etc.
in your case, do you lose lights/radio/any electrical when this happens. it could still be a bad/intermittent power connection
PostPosted: Tue Aug 25, 2009 1:23 pm
Year and Trim: 1999 Oldsmobile 88 LS
I second that. Try the battery terminals
PostPosted: Wed Aug 26, 2009 1:58 pm
Year and Trim: 1993 Bonneville SE, restoration finished
I "third" the battery cables, insomuch as it is the most common and easiest thing to check. Had this happen a few times on my 1999 Olds eighty-eight. Keep in mind that mine looked fine, then I removed them and found they were a mess inside.
1993 SE with SLE appearance package. Factory stock except for steering wheel buttons, AM/FM/CD from a '93SSEi and chrome wheels.
1999 Olds Eighty-Eight LS Anniversary Edition, my daily driver.
2004 Chrysler Minivan, wife's daily driver.
There are no new unread posts for this topic. my car just shuts off for no reason. well some reason
trgrhpy
Fri Jan 20, 2017 8:13 pm
Bugsi View the latest post
There are no new unread posts for this topic. 1999 Bonneville Shuts Off While Driving
dom4206
Tue Jan 28, 2014 9:58 am
There are no new unread posts for this topic. 1999 SLE engine suddnely shuts down
adinini
Sun Oct 24, 2010 12:40 pm
There are no new unread posts for this topic. 98 Bonnie shuts off while driving. sometimes. PLEASE HELP.
chevrolet.power.420
27
2619
Sun May 01, 2016 12:38 am
StraTact View the latest post
There are no new unread posts for this topic. starts and shuts off
95bonneville
Wed Nov 02, 2011 3:36 pm
95bonneville View the latest post
