It is currently Sat Sep 22, 2018 11:32 am
 Post subject: Unreadable codes
PostPosted: Thu Aug 06, 2009 9:35 am
Year and Trim: 1995 bonneville SE
I have a 1995 Buick Le Sabre,(basically a bonneville with Buick nameplates), 3.8 ltr. Car was running then just shut down, no spark. Changed the crank sensor, started back up and ran fine. This was a month ago, yesterday same thing happened, plugged in my code scanner with the proper chip. Scanner reads "cannot communicate with vehicle". Has anyone else had this problem and if so what was the cause. I pulled the ecm thinking maybe there was an issue with that but it seems to be fine.
 Post subject: Re: Unreadable codes
PostPosted: Thu Aug 06, 2009 9:40 am
Site Owner/Webmaster
'01 Sierra C3
I know the 95 Bonneville was a weird year where it had an OBD2 connector, but an OBD1 computer (commonly called OBD1.5). My guess is you are trying to scan it as an OBD2 which won't work. You need an OBD1 scanner with an OBD2 cable. I'm not 100% sure that the buick followed suit, but I assume it would.
Owner / Admin
1995 SSEi / 2002 SSEi / 2001 Sierra C3 DENALI
PostPosted: Thu Aug 06, 2009 9:56 am
I'm using a snap-on scanner with the "K-9" chip. Scanner worked fine on my 95 Bonneville just not on the Buick.
PostPosted: Thu Aug 06, 2009 9:24 pm
Remove the chip, then let the scanner determine the chip needed. There's a very slight chance that the Buick may call for a different chip. Just give that a shot, and report back.
PostPosted: Fri Aug 07, 2009 12:14 am
The Protocall for both the 1995 L36 and the 1995 L27 is the same, but the Programing and the way it functions is different..
By all rights any tool that will read a 95 bonneville should read the 95 Le Sabre..
PostPosted: Tue Aug 11, 2009 1:56 pm
Scanner calls for the "k-9" key chip for that vehicle. As a side note, I pulled the ecm from the Pontiac and plugged it into tbe Buick. Viola!! I can now read the codes. Po325 Knock sensor circoit. I'm thinking the ecm is bad in the Buick.
PostPosted: Tue Aug 11, 2009 3:05 pm
Engine "clunk" seems to come from the trans. end of the engine, toward the firewall. I've unplugged every sensor I can see to see if I could locate the problem. So far no luck. I don't think it is in the engine bottom end. It doesn't do it all the time, just occasionally. But when it does it really is loud. The engine doesn't change rpm or anything.
There are no new unread posts for this topic. Help with codes
JMH1950
31
2082
Wed Oct 29, 2008 3:34 pm
JMH1950 View the latest post
There are no new unread posts for this topic. codes
thunderhand
Mon Nov 17, 2008 11:19 am
sandrock View the latest post
This topic is locked, you cannot edit posts or make further replies. Air Bag Codes
nunesjeff
Mon Nov 16, 2009 9:12 pm
J Wikoff View the latest post
There are no new unread posts for this topic. A few codes...ugh.
ddalder
Sat Sep 30, 2017 4:24 pm
ddalder View the latest post
There are no new unread posts for this topic. A couple of codes: Can you help, please??
labonnevillastrangiato
Mon Jul 21, 2008 8:49 pm
93RedSled-SSE View the latest post
Users browsing this forum: Google [Bot] and 7 guests
