It is currently Wed Apr 25, 2018 4:41 am
PostPosted: Thu Jun 25, 2009 12:26 am
Year and Trim: 92 bonneville se
I have a 92 bonneville that won't start after runnung for a while. It just turns over and over and won't fire up there is no spark while turning over either. i am getting a 17 code and a 21 code. It should still fire up with the 17 code but the other one maybe not. i believe the 21 code is spark reference circiut is it not?? Could this either be icm or the pcm. Thanks for your interest..
Thanks, Dan
PostPosted: Thu Jun 25, 2009 4:30 am
Sounds like it is the crank position sensor. It gets the spark reference from a ring on the harmonic balance. Check the connection down by the crank pulley.
PostPosted: Thu Jun 25, 2009 7:15 pm
O.k> i will give that a try . when i was outside last night and trying to start it while it was hot and thought to grab the air gun and put some air under the icm and blew some air on the crank sensor as well, and i don't know if was just the time when it kicked back in or not but it started right up . I'm going to start it up again and try it again on each. the crank sensor first and if that doesn't on the icm.
There are no new unread posts for this topic. Wont Stay Running
redwingsfan34
Wed Nov 04, 2009 3:02 pm
bill buttermore View the latest post
There are no new unread posts for this topic. 97 bonnie wont stay running please help!!
lilanqel94
11
1043
Thu Apr 02, 2015 8:34 pm
lilanqel94 View the latest post
There are no new unread posts for this topic. Car wont start! need help
calaeb0896
Tue Jul 15, 2008 2:17 pm
zuper8 View the latest post
There are no new unread posts for this topic. wont start
irish91983
19
2309
Wed Jul 07, 2010 2:31 pm
irish91983 View the latest post
There are no new unread posts for this topic. car wont start
amanda
Sat Jan 07, 2012 2:26 am
RPACODY View the latest post
Users browsing this forum: Google [Bot] and 11 guests
