It is currently Mon Feb 18, 2019 12:05 pm
PostPosted: Fri Jun 19, 2009 10:17 am
Year and Trim: 1997 SSEi 40th Anniv
hi,
i recent got a 97 ssei and decided to tune/freshen up all maintaince items fluids, plugs/wires filters, belts etc. while changing the plugs and wires i notice the evap switch has 3 vacuum elbows on it. one comes fromthe evap canister purge valve, one goes to the canister and the third one on the bottom of the evap switch does not have a line connected. the only other line i see in the area goes between just below the s/c nose and the map sensor(s) under the evap switch.
the third vac line is not on the diagram on the radiator support. i have spent a couple hours googling to no avail...
does anyone know where this third line goes to? i could back trace it if i knew.
tia,
peter
PostPosted: Fri Jun 26, 2009 2:08 pm
Location: Phoenix, Arizona WCBF '05, '06, '07, '08 - NEBF '07
1993 SSE
From everything I have researched, the third is not connected to anything. I thought the same thing.....there must be something that connects to it, but it doesn't, and I have confirmed this with several (at least 5) other '97 owners. Mine has a rubber elbow on it that just points toward the firewall.
"Really Not Stock Anymore" Bob and most recently renamed, "Chief BadLifter"
SingsCountry1967 wrote:
I can babysit your car for the week... or rent it.... I won't race it I swear <fingers crossed>
Best ¼ ET=13.674, Best 60’=2.122, Best Trap=102.26 mph Pacesetter headers (2.5" outlet), Magnaflow hi-flo cat, INTENSE FWI w/K&N 9" cone, ZZP XP cam, INTENSE OR pushrods, Comp 105 springs, Autolite 103 plugs, Stoppenbach tuned PCM
PostPosted: Fri Jun 26, 2009 2:24 pm
Year and Trim: 1999 SSEi
1997 SSEi-Resting-353K
confirmed on mine, bottom one has a rubber elbow to nothing, the one the points to firewall goes to canistor
PostPosted: Fri Jun 26, 2009 7:24 pm
thanks guys.
someone pointed out that in the pix i sent, the "port" in question was not barbed and it was probably a vent to the atmosphere...this deduction seemed reasonable. i appreciate your checking for me.
peter
There are no new unread posts for this topic. Where to find lines from TB to EVAP
justhalc
Sun Aug 25, 2013 2:37 am
motopsyco View the latest post
There are no new unread posts for this topic. 94' SSEI AC EVAP.
smp3371
Thu Jun 05, 2008 1:29 pm
93RedSled-SSE View the latest post
There are no new unread posts for this topic. 98 SSEi dreaded P0300 after changing FPR and vacuum lines
sgmburke
Thu Jan 21, 2016 7:55 am
sgmburke View the latest post
There are no new unread posts for this topic. 99 SSEI Electronic A/C Vacuum Lines/Diverter:Location?
FIREREALTY
Tue Oct 06, 2009 6:38 pm
There are no new unread posts for this topic. Part # for oil pressure switch? (96 SSEi)
Boreas
Sat Sep 06, 2008 3:43 pm
Pontiac1 View the latest post
Users browsing this forum: Exabot [Bot] and 12 guests
