It is currently Sat Feb 16, 2019 6:07 am
 Post subject: Light monitor
PostPosted: Sat May 23, 2009 3:57 am
Year and Trim: 1992 Pontiac Bonneville SSEi - L67 Series 1 - 131,000 Miles.
I am driving and my lamp monitor comes on. No line signifying a specific spot for the light thats out. No words either. I hit a bump and EVERY light monitor light comes on. Tail lights, high beams, parking lamp, etc.
Give it a few seconds (normally when I hit another bump) and it all goes back to normal. No light monitor at all.
Any idea what this could be? I know it must be a loose/dirty connection but where do these lights all have a central connection at?
 Post subject: Re: Light monitor
PostPosted: Sat May 23, 2009 10:54 am
Sounds like the cluster is freaking out. See if you can find another at a JY and try it.
PostPosted: Sat May 23, 2009 12:35 pm
I've heard about several problems with lamp monitors. Someone with experience in your model year will likely answer your question and provide some diagnostic tips. Have you tried searching topics related to this yet?
PostPosted: Sat May 23, 2009 3:24 pm
Year and Trim: 2002 Mazda Protege ES
does the DIC ever flicker or turn off?
-Matt
PostPosted: Sun May 24, 2009 12:38 am
Yes the digital interface has flickered to the point of turning off before. The last time it did that was about 4 months ago though. Today the front turn signal lamp popped on for 5 seconds.
Nothing much from searches.
There is nothing else that controls these codes besides the dash?
There are no new unread posts for this topic. Low coolant, Lamp Monitor, Brake/tail light warnings
Troxartes
Sat Jun 08, 2013 6:49 pm
Pontiac1 View the latest post
There are no new unread posts for this topic. Oil Life Monitor?
LeSabre in Buffalo
Sun Sep 07, 2008 8:06 pm
There are no new unread posts for this topic. Heads Up & Car Monitor
ernie44golf
Sun Jan 15, 2012 5:21 pm
willwren View the latest post
There are no new unread posts for this topic. How to trick the lamp monitor?
SSEiMan01
Fri Jan 31, 2014 2:13 pm
There are no new unread posts for this topic. P1652 IAC Monitor Disabled by PSP Switch Failed On
anwisdom
Tue Sep 30, 2014 1:40 pm
anwisdom View the latest post
Users browsing this forum: Google [Bot] and 14 guests
