It is currently Tue Sep 22, 2020 1:52 pm
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
PostPosted: Tue May 12, 2009 2:53 pm
Hmm. When my balancer was dying, it would make clunking noises when I started or shut off the engine.
PostPosted: Tue May 12, 2009 4:05 pm
Year and Trim: 93 bonneville ssei sedan
i took it up to a shop and their leaning towards balance. their saying that the balance is going bad cause the balance is two pieces and the outside that runs the alt could be bad.sound right?
93 ssei
cold air kit
new super charger
clear corners
PostPosted: Tue May 12, 2009 4:47 pm
There is an inner hub bonded to a grooved outer ring with rubber. The rubber can degrade and crack. Then the outer ring is left to rattle around the outside of the hub. It is designed to continue to work if the rubber gives out, but it's loud.
PostPosted: Tue May 12, 2009 5:32 pm
can u tell me how to keep the balance from turning im trying to get the bolt out.thanks
93 ssei
cold air kit
new super charger
clear corners
PostPosted: Tue May 12, 2009 6:40 pm
Does the rubber looked cracked at all?
Take the plastic cover off the bottom driver side where the engine meets the transmission. Find a way to jam a screwdriver in the flywheel teeth. Or you can use an impact wrench to just zip it off.
PostPosted: Tue May 12, 2009 7:20 pm
OK I GOT IT OFF,THANKS
93 ssei
cold air kit
new super charger
clear corners
PostPosted: Sun May 17, 2009 7:11 pm
ya! the balance is replaced and the noise is gone. the other balance was shot............thanks everybody for the help
93 ssei
cold air kit
new super charger
clear corners
There are no new unread posts for this topic. '98 SLE - Grinding noise
SATADrive420
Wed Oct 30, 2013 10:09 am
There are no new unread posts for this topic. Grinding Noise From Intake and Poor MPG
stealthmode
17
2092
Thu Apr 14, 2011 2:30 am
There are no new unread posts for this topic. High-Pitch Grinding Noise while driving
StraTact
Sun Jul 12, 2020 1:34 pm
StraTact View the latest post
There are no new unread posts for this topic. 93 wierd grinding noise trans issue
lackawanna1701
Wed Nov 16, 2011 10:12 pm
lackawanna1701 View the latest post
There are no new unread posts for this topic. Rubbing/Grinding Noise on Heavy Launch on 94 SSEi w/ vid
putertopia
19
3531
Sun Jan 04, 2009 6:22 pm
putertopia View the latest post
