It is currently Tue Apr 16, 2024 1:44 pm
 Post subject: Delta 88 Gauge Swap
PostPosted: Thu Jan 29, 2009 3:10 am
Year and Trim: 1989 Oldsmobile 88 Royale Brougham Regency - FE3
I'm looking to swap a gauge cluster with a tach into a non tack clustered 89 Olds Delta 88.Anyone know if a 87-91 Delta 88 came with a tachin the cluster? If not does the Buick Lesabre have a model with a tach in the gauge cluster?
I think the Bonneville cluster would'nt fit in the Delta 88 from the way it looks.
1989 Oldsmobile 88 Royale Brougham Regency - Grey on Grey - FE3 - X06 Package - Limo Tint - Clarion HU - 2K Pontiac Grand Am 15" Alloy Rims
 Post subject: Re: Delta 88 Gauge Swap
PostPosted: Thu Jan 29, 2009 7:33 pm
Year and Trim: 1990 LeSabre
I don't think that the Lesabre cluster will fit the olds. The Olds cluster with a tach is standard on the 98 Touring Sedan model of those years (through 90) and should fit. However, you will probably need a whole new harness or to re-pin it at minimum. You will most likely need to run a wire to the coil pack for the tach signal. Depending on your current gages, you might also need temperature and oil pressure senders, not switches.
matt
1990 Buick LeSabre Limited 100k - Black Sapphire Metallic
Mods:
Strut Tower Brace, Type II Delco Ignition with MSD Coils, Delco 140 amp alternator, 89 Electra/PA CD Player, Audiovox CommanderMT XM Radio, V08 HD Cooling Radiator with Second Fan, 3/8" Transmission Cooling Lines, B&M Aux Transmission Cooler, F41 Front & Rear (Air) Struts, F41 Front & Rear Sway Bars, 96-00 Buick LeSabre/PA 16" wheels and tires, 89-91 SSE Console/Shifter, Class II Trailer Hitch and Wiring, $1000+ in Second Skin Sound Deadening Material, LeSabre T-Type Cluster, 91-92 Buick Century Steering Wheel Controls. Amsoil SSO 0W30 and Amsoil ATF.
Next: Cadillac FWD V8 Braces, F41 Springs, 1988-1991 Olds A/W/C/H -body Driver Info Center (already wired, waiting on a mount)
2003 Mercury Grand Marquis LSE 153k - Silver
Mods:
Pioneer AVIC X910BT Navi, 2010/2011 Mustang 18" Wheels, Class III Trailer Hitch and Wiring, Amsoil in Engine, Trans, and Differential. Damaged Jan 2012 - waiting on adjuster to determine fate -
PostPosted: Fri Jan 30, 2009 6:18 pm
Lesabe cluster will not fit. Bonnie cluster will not fit.
As stated, you need a cluster from a Touring Sedan, which are few and far between unfortunately. The tach will probably work off the signal from the ECM but you will have to wire in the coolant temp and oil pressure senders (not to mention buying them and the housing for the oil pressure).
The UIM already has a tapped hole for the temp sender but its filled in with a bolt. The oil pressure sender is a matter of removing the current oil filter housing, getting one with a sender from a junkyard, buying a new sender as the old ones are notorious for going bad, and then wiring them.
You may or may not need to add pins to the wire harness but buying an electrical manual would tell you (`$20 off eBay).
-Eric
-1987 Fiero GT: 224k miles
PostPosted: Sat Jan 31, 2009 4:44 am
Hmmm. Thanks for the info. Looks like I may just hook up an aftermarket tach instead then. Where would I connect the wire for an aftermarket one on the Delta 88?
PostPosted: Sat Jan 31, 2009 4:48 am
There is a wire from the ECM that comes from the tach that you could splice into. I don't recall which one it is off the top of my head but if you searched for wire diagrams online you may find it. I found it when I was looking up how to install a remote start as they ues the tach to tell when the motor is on.
-Eric
There are no new unread posts for this topic. 89 Gauge Cluster Swap
Bmstad
Wed Jan 09, 2013 11:10 am
There are no new unread posts for this topic. Battery Requirements for Olds Delta 88
89OldsRocket
Fri Oct 25, 2013 3:18 am
rustyroger View the latest post
There are no new unread posts for this topic. 1987 Olds Delta 88 coil pack.
rustyroger
Thu Jul 28, 2016 3:04 pm
MKMike View the latest post
There are no new unread posts for this topic. 1989 Oldsmobile Delta 88 Frnt Wheel Bearing Re n Re
89OldsRocket
Sun Sep 18, 2016 6:22 pm
89OldsRocket View the latest post
There are no new unread posts for this topic. 1987 olds delta 88 royale has code 44 and stalls instantly .
88bonnsse
Sat Mar 01, 2014 8:22 pm
J Wikoff View the latest post
cron
