It is currently Tue Jul 14, 2020 3:04 pm
PostPosted: Mon Jun 10, 2019 1:53 am
Year and Trim: 3800 1990
What are differences? Only + wire mount?
I have broken alternator on my 1990 and my friend has 1993 trans sport (3.8 v6) alternator but its on miles away so will someone know will that fit?
Same alternator which fits trans sport fits same age bonneville
PostPosted: Mon Jun 10, 2019 11:49 am
Its 140a model but im happy to know will it fit or will 105a model on newer models fit.
PostPosted: Mon Jun 10, 2019 8:50 pm
It's not looking like it's a direct swap:
07 Infiniti G35s 6MT
PostPosted: Tue Jun 11, 2019 9:37 am
Seems like attachments are reversed, but if those are same size, you just turn alternator another way?
Only problem is, is there enough room for fatter 140a alterntor and is belt routing in same distance. I mean is measure same pulley top to alternatoe case.
Its possible to turn alternator bottom in another side if + wire connection is too low.
I wonder basic 105a newer alternator is easy to fit but bigger 140 :dontknow:
PostPosted: Tue Jun 11, 2019 10:40 pm
Honestly, without trying it, I doubt you'll know for sure one way or another.
PostPosted: Wed Jun 12, 2019 6:47 am
you gotta make sure the mount positions are the same take good pictures + measure: you can always make your own bracket for mount.
you can always have your own alternator refurbished.
PostPosted: Mon Jun 24, 2019 1:34 pm
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
I know I'm late to the party here...
Yes, the 93 alternator will physically fit, but some modifications are needed. In addition to mounting reversed, the orientation of the output stud (as well the angle and tab on the big wire) are different and need to be modified.
I had one on my '89 Lesabre for a while, not bolt in but can be made to work.
PostPosted: Wed Jun 26, 2019 12:25 pm
I got it and it places fine even + wirr bolt but engine harness is stuck on bottom.
So alternator wont touch smaller bolt hole.
Longer belt or harness with new location will help.
PostPosted: Fri Jun 28, 2019 2:10 pm
'05 STS-4
'97 LeSabre
I vaguely recall pushing some wires out of the way. It was a while back, so I couldn't tell you if I had to un-tape the loom or what I did to get around that. I think it's the harness that went down to the crank/cam sensors.
There are no new unread posts for this topic. 1990 bonneville will not idle
Frustrated1
Sun Sep 24, 2017 10:38 pm
Frustrated1 View the latest post
This topic is locked, you cannot edit posts or make further replies. 1990 Bonneville SSE Oil Cooler?
retroren
Thu Nov 13, 2014 8:59 am
J Wikoff View the latest post
There are no new unread posts for this topic. 1990-91 Bonneville Information.
Benvw99
14
3287
Fri Feb 13, 2015 4:47 pm
Benvw99 View the latest post
There are no new unread posts for this topic. 1990 Pontiac Bonneville GM Service Manual
72buickgs
Tue Jul 22, 2014 10:49 pm
72buickgs View the latest post
There are no new unread posts for this topic. IS 1989 Toronado Trofeo, 1990 Bonneville same air pump?
SSEBonne4evr
Fri Nov 30, 2012 12:04 pm
cron
