It is currently Sat Jan 23, 2021 7:12 am
PostPosted: Fri Jan 04, 2019 2:58 pm
Year and Trim: 1987
What is the recommended tire pressure for 87 Bonneville, please? Tires are P205/75R14. Tire placard on driver's door is faded, and this information is omitted from owner's manual and shop manual.
PostPosted: Sat Jan 05, 2019 12:56 am
I recommend figuring it out based on your tires currently fitted, as they are likely rated differently than the originals fitted stock.
For example, my '93 PA lists 32 psi on P205/70R15 tires. When I ran that, it was obviously not happy. Airing the front tires to 40psi (44 was the max for the tires) kept a happy medium.
I currently run P215/70R15s on that car at 38psi in front, 35 in rear.
PostPosted: Sat Jan 05, 2019 10:07 am
Year and Trim: 1987
Thank you VERY much
PostPosted: Sun Jan 06, 2019 2:30 pm
And to clarify, I am sure there could be some complex equation that calculates the exact pressure based on the exact load, but I just did it by observation. At the lower pressure, it was obvious the tire was setting too low on the sidewall, and wore the shoulders of the tire excessively. When over-inflated, the ride was quite harsh, like the car was riding on a ring of concrete instead of nice squishy tires.
If I was guessing, I would start at the max for the tire rating, and keep backing it down until it 'feels right'. You'll know it when you hit it. Once you hit it, you can check what the pressure is, and should be set. Every time the car goes in for service, I request specific tire pressures, and it nails it every time if they do it right.
PostPosted: Sun Jan 06, 2019 9:59 pm
Year and Trim: 1987
Thanks. Getting new tires tomorrow and want to start off on the right foot.
There are no new unread posts for this topic. Wheel and tire fitment
Adjemo87
Sat Apr 08, 2017 4:33 pm
Adjemo87 View the latest post
There are no new unread posts for this topic. 193,000 miles and can't build up oil pressure
PocolocoBob
Thu Mar 14, 2013 6:45 pm
PocolocoBob View the latest post
There are no new unread posts for this topic. Power steering pressure switch
pontiacsteve22
Fri May 10, 2013 7:19 pm
pontiacsteve22 View the latest post
There are no new unread posts for this topic. 1993 bonneville/trans sport alternator to 1990 bonneville?
Karpov
Fri Jun 28, 2019 2:10 pm
There are no new unread posts for this topic. 91 Bonneville LE Questions
oddie121
26
6176
Sat Nov 09, 2013 4:25 pm
Zeik75 View the latest post
