It is currently Mon May 20, 2019 7:22 am
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sat Sep 08, 2018 9:40 pm
So I read my 95's FSM on fueling thinking the basic concept will be the same. One thing that I didn't really know what that when the evaporator system is purging it says the INT could be as low as 90. But, the engine must be running in closed loop for the EVAP to be on. I'm assuming your 90 has an EVAP system.. It might not.
One thing you may want to double check is continuity of the wire going from the PCM to the O2 sensor. I'm pretty sure you just have a one wire O2 sensor. If it's grounding out intermittently, that could explain a lot.
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
PostPosted: Sun Sep 09, 2018 3:23 am
Year and Trim: 3800 1990
Yes i have one wire o2. Ex owner had 10 years ago grounding problems with sensor because one exhaust manifold bolt was missing.
PostPosted: Sun Sep 09, 2018 10:41 am
unplug the o2 sensor for test run - more fuuel consumption but should run fine if o2 is issue
PostPosted: Sun Sep 09, 2018 11:09 am
Can someone check what int and blm is when revving 4000rpm on idle? Or maf mg count?
There are no new unread posts for this topic. 91 Bonneville LE Questions
oddie121
26
5324
Sat Nov 09, 2013 4:25 pm
Zeik75 View the latest post
There are no new unread posts for this topic. 91 Bonneville Shaking
extrabigjon
16
2703
Fri Apr 27, 2012 3:20 pm
extrabigjon View the latest post
There are no new unread posts for this topic. 1987 Bonneville timing
pontiacguy87
Wed Oct 19, 2016 9:16 am
There are no new unread posts for this topic. '89 Bonneville stalls at Idle
Stephen
16
6732
Fri Mar 30, 2012 3:50 pm
murderedout View the latest post
There are no new unread posts for this topic. 90 Bonneville LE - Vibration when braking
ponbon
Sat Jun 30, 2012 9:01 am
