It is currently Mon May 20, 2019 1:22 am
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sat Aug 18, 2018 5:27 pm
Year and Trim: 3800 1990
96 SSEi wrote:
you have a scantool that pulls o2 volts so diagnose the sensor - not that hard, then check injectors
O2 sensor shows 400-700mv. Not stable.
PostPosted: Sat Aug 18, 2018 5:57 pm
the front, pre cat is supposed to fluctuate from very low to high - my 2000 is from .03 to .75 - if it stays steady within a range then it is slow or going bad. the post cat sensor stays in a range around .450
PostPosted: Sun Aug 19, 2018 12:28 am
Post cat O2 sensors didn't exist until OBD2 96+
I'm not sure what the stock mv reading should be for the O2s or how fast it should oscillate.
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
PostPosted: Sun Aug 19, 2018 9:49 am
Your opinions about videos? (Aijaa.com links)
Tps adjust did tcc to work smoother!
I must order new 02 and injector o rings.
But can faulty 02 do heavy cutting on engine at higher rpm?
PostPosted: Mon Aug 20, 2018 12:23 pm
Which videos?
If the O2 sensors are worn/old it won't be able to adjust the fueling correctly, causing a drop in gas mileage.
05 Suzuki DRZ400S
PostPosted: Mon Aug 20, 2018 3:19 pm
95naSTA wrote:
Which videos?
Now i have video what car does in acceleration and idle. I have aldl connected on idle when car sputters.
https://aijaa.com/AlMOQK idle poor running with tuner pro on
https://aijaa.com/hOUFp1 sputtering was mild. Its usually worser
When you open link, there is video
PostPosted: Mon Aug 20, 2018 10:13 pm
I would not revving the engine with no load that high in idle or park. It's really lean up there BLM of 150+ but I would expect that since there's no load.
The driving video showing the shift seems like the transmission slips or the engine hits a limiter at the top of the shift.
05 Suzuki DRZ400S
PostPosted: Tue Aug 21, 2018 5:44 am
In drive its usually same that park. Rev limiter is just after 5000rpm and its smooth. Not in 4000rpm. It seems like slip but engine surges and then rpm drops.
I know its not healthy to rev in park, but there is some problem its not that kind when its working correctly.
In carb engines lean mixture pops and bangs in heavy throttle. So if you see lean mixture on that rev video it can be the problem.
But what makes engine lean on high rpm?
Fuel filter is good and new like fuel pump. And fuel pump gives healthy pressure.
PostPosted: Tue Aug 21, 2018 9:41 pm
The only thing I can think of is the O2 sensors then.
05 Suzuki DRZ400S
PostPosted: Wed Sep 05, 2018 9:27 am
Now i have new delphi o2 sensor and i cleaned injectors.
Now o2 volts are 90-900mv in idle. Afr was 13.7 until i pressed gas.
Block learn multiplier was 105 and fine fuel correction 135.
PostPosted: Thu Sep 06, 2018 10:47 am
Today measuring and testing. Now car is open loop all the time even its warm. Restart didnt effected or just ecm fuse reset.
What can cause that? No fault codes
PostPosted: Thu Sep 06, 2018 3:07 pm
I'm having a rough time with this one.
Low coolant temp and an unplugged O2 sensor can keep the car from going into open loop but I'm not sure what else.
05 Suzuki DRZ400S
PostPosted: Fri Sep 07, 2018 8:15 am
Temp sensor is pretty new and it shows like it should.
New o2 sensor has been in now about 100miles.
Every day when i look thru my homes window and see bonneville in parking slot, i wonder what so bad i have been done that american engineers punish me like this :D
PostPosted: Fri Sep 07, 2018 8:19 am
I tried to take fuel regulator hose off which richened idle etc. Blm was 105-110 and fine fuel same.
Why fine fuel correction wont try fix it 128 or why stock adjust is all the time rich (only 4000rpm it was lean)
PostPosted: Fri Sep 07, 2018 12:04 pm
If you were in closed loop, the BLM being low with the vacuum reference off makes sense. Vacuum helps open the regulator to return the fuel and give lower fuel pressure.
You have a base fuel map the the BLM tells the ECU how much more or less fuel to deliver from that base map. The INT is the short term memory and it's trend changes the BLM. The closer you are to 128, the less your ECU is compensating and generally should run better.
From what I understand, if the ECU is in open loop, the INT never tells the BLM how much to adjust.
05 Suzuki DRZ400S
PostPosted: Fri Sep 07, 2018 3:05 pm
In normal situation i had 120-110 values both. Vacuum of it dropped, it was just test.
It has not been in open loop befote ar warn engine, now it is
So many things are wrong :(
What all causes and things effect blm and int? Sensors etc
PostPosted: Fri Sep 07, 2018 8:20 pm
The only thing that impacts the BLM and INT is the O2 sensor input.
05 Suzuki DRZ400S
PostPosted: Sat Sep 08, 2018 1:17 pm
Maf does not effect?
PostPosted: Sat Sep 08, 2018 1:36 pm
Think about it as a feedback loop. Initially, fuel is determined by LV8 (load) and rpm. Load is determined by MAF, air temp, etc. The O2 sensor sees whether or not the fueling is correct, assigns an INT number (short term memory), trends the BLM (long term memory) and then fueling is adjusted from the base map accordingly.
The MAF doesn't have a direct influence on the INT/BLM. Only after the O2 sees how much oxygen is in the exhaust, does the INT and BLM change.
05 Suzuki DRZ400S
PostPosted: Sat Sep 08, 2018 3:50 pm
New o2 sensor is coming to me. I just wont believe that new o2 sensor fixes my problem
This car's engine management system is mess and im very much out for that :(
I dont understand why its open loop in hot engine and aometimes not. I understand if there is some "2minutes aster start closed loop if engine is hot" but it wont do it even 30minutes on driving, if its bad day.
There are no new unread posts for this topic. 91 Bonneville LE Questions
oddie121
26
5324
Sat Nov 09, 2013 4:25 pm
Zeik75 View the latest post
There are no new unread posts for this topic. 91 Bonneville Shaking
extrabigjon
16
2703
Fri Apr 27, 2012 3:20 pm
extrabigjon View the latest post
There are no new unread posts for this topic. 1987 Bonneville timing
pontiacguy87
Wed Oct 19, 2016 9:16 am
There are no new unread posts for this topic. '89 Bonneville stalls at Idle
Stephen
16
6732
Fri Mar 30, 2012 3:50 pm
murderedout View the latest post
There are no new unread posts for this topic. 90 Bonneville LE - Vibration when braking
ponbon
Sat Jun 30, 2012 9:01 am
