It is currently Mon Jul 13, 2020 6:04 pm
PostPosted: Wed Nov 22, 2017 8:21 pm
Year and Trim: 1989 Bonneville SSE
Hi again..Seem to have a small weepage from the oil adapter housing we think. I have the oil, trans cooler lines on mine, from a 89 bonnie sse. Looking in the part book, I was confused as they show the housing is part # 24501466. Then part number 24500022 comes off of that, with a seal in between. to connect the cooler lines and oil filter itself.
My question is, does anyone know if the two parts seperate from each other, the housing part that has 4 bolts that attach to the block, and the part numbered 24500022, which has the two cooler lines that come off of it.
We rebulit a 3800 V6 Vin C FROM A 1990 Buick Reatta, which , at least the one I got salvage, didn't have the cooler line capable oil filter housing adapter, so we had to go with the one from my original engine that did have the cooler line option.Wheew..lot of verbage to explain this one..lol..
Once we carefully observe these parts with the car running, up on ramps, we will be able to tell hopefully where exactly the leak is coming from. Knowing about how this oil adapter can be configured, if the cooler line adapter seperates from the housing, will help jus fix it. Thanks..
PostPosted: Wed Nov 22, 2017 9:25 pm
It should, yes. I have or had one from a Series 2. The part the cooler lines came out of bolted to the actual adapter by the stud the oil filter screws onto and there's a flattened o-ring to seal it.
Looked like this:
wanted/topic5231.html#p52210
07 Infiniti G35s 6MT
There are no new unread posts for this topic. fuel filter replacement
PocolocoBob
Tue Feb 12, 2013 9:01 am
PocolocoBob View the latest post
There are no new unread posts for this topic. 90 regal fuel filter
haro1225
Thu Aug 13, 2009 12:39 pm
haro1225 View the latest post
There are no new unread posts for this topic. Fuel filter help needed
Tonioseven
Sat Aug 02, 2008 11:40 am
Tonioseven View the latest post
There are no new unread posts for this topic. Recently replaced fuel filter.
tom804
Thu Feb 07, 2013 11:23 pm
There are no new unread posts for this topic. Coolant leak, and a question
crzydmnd72
Sat Jan 31, 2009 7:57 pm
crzydmnd72 View the latest post
