It is currently Sun Feb 17, 2019 8:42 am
 Post subject: Tail Light Lenses.....
PostPosted: Sat Oct 14, 2017 4:09 am
Year and Trim: 1989 LE Bonneville
Guys, I need to find a couple new lens, and could also use come guidance about how to install them. Thanks :)
PostPosted: Sat Oct 14, 2017 12:48 pm
The only lenses I have seen are NOS units on Ebay, which command a very hefty premium. This is also just the clear outer plastic typically, and doesn't include the colored lens.
Typically the best approach is to source an entire taillight assembly from salvage. There are 3 styles to be aware of, the early base model units (solid red), the later base model units (amber, red, clear, with clear outer lens), and the SSE units (amber, red, clear, with smoked striped outer lens).
If you intend to replace just the outer lens, it requires separation of the lens using careful application of heat and pressure, with a high risk of breaking nearly 30 year old plastic in the process.
Replacing an assembly is simply a matter of loosening the nuts from inside the trunk and sliding the light assembly out.
There are no new unread posts for this topic. '88 Bonne Tail light lenses
dandyd
14
3745
Wed Sep 10, 2008 4:55 am
neelix6555 View the latest post
There are no new unread posts for this topic. 90 SSE Tail light
George73
Mon Jul 18, 2016 4:52 pm
96 SSEi View the latest post
There are no new unread posts for this topic. Tail light covers
Don Williams
Tue Sep 22, 2009 12:04 am
spidey3479 View the latest post
There are no new unread posts for this topic. 88-89 Bonneville Tail Light Lens
dandyd
Tue Jun 10, 2014 2:05 pm
There are no new unread posts for this topic. 90 sse security light
Don Williams
Sat Apr 10, 2010 10:12 am
willwren View the latest post
