It is currently Mon Jul 13, 2020 8:58 pm
PostPosted: Fri Oct 13, 2017 1:32 pm
Year and Trim: 1987 Oldsmobile Delta 88
1989 Buick Le Sabre
The bearing in the belt tensioner in my 1987 Delta 88 is noisy and has excessive play.
I can't go to the local junkyard and get another one, the nearest one is probably 3000 miles away! :)
I intend to remove the pulley and replace the bearing, it's worthwhile in my circumstances.
I'm guessing the pulley bolt is left hand thread?. I don't want to turn it the wrong way and break it. If it breaks going the right way, well that's too bad.
Thanks in anticipation,
Roger.
PostPosted: Fri Oct 13, 2017 2:55 pm
please inspect the pulley rotation direction under normal operation. the pulley should always spin in the fasten direction so you will apply force in the unfasten( opposite) direction.
so if the pulley is rotating clockwise, you will go counter clockwise
it gets weird when the pulley is rotating counter clockwise and you remove it by applying clockwise direction. which is counter intuitive cause that is usually the fasten direction but not in that specific pulley application
PostPosted: Sat Oct 14, 2017 12:46 am
1989 Buick Le Sabre
The pulley does rotate counter clockwise.
I tried turning it clockwise but it was very tight.
Now I can go put a bigger wrench on it knowing I'm not making thins worse.
Thank you.
Roger.
PostPosted: Sat Oct 14, 2017 9:27 am
OK, good luck, post back with progress.....later
PostPosted: Sat Oct 14, 2017 9:51 am
On old corroded bolts try tightening them first to break them, then loosen.
07 Infiniti G35s 6MT
PostPosted: Sun Oct 15, 2017 2:38 pm
1989 Buick Le Sabre
A bit of effort with a longer 18mm wrench and off it came. It is lh thread btw.
A sharp tap with a hammer and drift and out popped the bearing.
id - 17mm
od - 40mm
width - 12mm
So off to the local bearing supplier in the morning, or £1.73 (about $2.40) from ebay.
Roger.
PostPosted: Wed Oct 18, 2017 9:05 am
1989 Buick Le Sabre
The new bearing arrived in the post today. £1.30 ($1.65) including shipping to my door. :2thumbup:
Ten minutes later I have silent running again.
A replacement pulley would have cost £7.32 + shipping and duties from Rock Auto.
I'm not complaining about their price, just pleased it was such a cheap and easy fix.
Roger.
There are no new unread posts for this topic. odd drive drop out at stop
county_line02
Fri Feb 22, 2013 9:54 pm
ajla View the latest post
There are no new unread posts for this topic. Stalls sometimes when going from reverse to drive, ect
Chris D.
Thu Feb 24, 2011 9:30 pm
There are no new unread posts for this topic. '91 SE Transmission disengages from drive after i stop.
Pepcfreak
Wed Aug 03, 2011 3:47 pm
Pepcfreak View the latest post
There are no new unread posts for this topic. Drive axle stuck half out
jimtea
12
2762
Sat Sep 26, 2009 10:57 am
jimtea View the latest post
There are no new unread posts for this topic. Mystery-Back Wheel Smokin After Drive!!!
89OldsRocket
Mon May 30, 2011 5:04 pm
