It is currently Thu Feb 21, 2019 3:16 am
PostPosted: Thu Oct 12, 2017 9:15 pm
Year and Trim: 1989 Bonneville SSE
Yes so my 1989 SSE is close to getting a new rebuilt engine! Got one from scrap yard, out of 1 1990 Buick Reatta. Had block gone through, just needed a cross hatch clean up of cylinders. Had a sweet 3 way head valve job done too. Everything else stock , same cam, pistons, crank. All properly cleaned and installed. Opinions on initial start up, oil to use, length of time for short oil changes? I know to stay away from Fram filters. Was thinking once she is broken in to go with Mobil 1 synthetic oil. But my mechanic friend wants me to initially use a staright 30 wt oil first, then change it and filter after 500 miles. Any suggestions?
PostPosted: Fri Oct 13, 2017 1:17 pm
Year and Trim: 1987 Oldsmobile Delta 88
1989 Buick Le Sabre
The Fram filter thing is a nonsense. Use tough guard or ultra guard and be happy you have as good a filter as you can get.
No need to overthink it, use whatever oil is recommended on the filler cap, 5w/30 or 10w/30 should be fine. Straight 30 oil won't get round the engine as quickly as 5w or 10w on a cold start - the last thing you want.
Pre pack the oil pump with vaseline or a light grease, and spin the engine with the spark plugs out until the oil light goes out to get oil round the bearings before firing it up.
Change the oil and filter after 500 miles.
Enjoy driving your car.
Roger.
This topic is locked, you cannot edit posts or make further replies. Series one engine rebuild
94SilverSSEi
Mon Jan 26, 2009 11:12 pm
J Wikoff View the latest post
There are no new unread posts for this topic. Trans rebuild
Dogluvr
Sun Jun 28, 2015 12:59 pm
Dogluvr View the latest post
There are no new unread posts for this topic. Very bad engine knock!
Zeik75
25
4654
Mon Jun 04, 2012 5:20 pm
Zeik75 View the latest post
There are no new unread posts for this topic. pull out 87 bonne engine
york.corp
Sun Oct 09, 2011 12:21 pm
There are no new unread posts for this topic. Engine running on 4 of 6 cylinders?
iriss
Fri Jul 15, 2011 1:36 am
Backhoe View the latest post
