It is currently Wed Jan 23, 2019 12:09 am
 Post subject: Replacing Spark Plugs
PostPosted: Fri Sep 22, 2017 2:29 am
Year and Trim: 1991 Pontiac Bonneville Se 3.8 engine
Hi everyone. I’m trying to learn about my car that I got from my dad a few years back. I was told that the spark plugs were simple to replace, but I’m not too sure on how to locate them in my car it is a 1991 Pontiac Bonneville with a 3.8 engine
PostPosted: Sun Sep 24, 2017 7:35 am
hi, welcome to the club!! you will see wires coming from a coil - there will be 6 - one wire going to each cylinder - at the end of the wire is the spark plug.
it would be wise for you to watch vids on youtube to get an idea. you will also need some standard tools with a spark plug socket - pretty standard these days
post back with your progress......later
PostPosted: Wed Sep 27, 2017 12:12 pm
Year and Trim: 1987 Oldsmobile Delta 88
1989 Buick Le Sabre
About as easy as it gets for a fwd V6 engine. No special tools required, a 3/8" drive socket set will be all you need. If you change the air filter at any time it might not be the obvious screws you need to undo.
Roger.
PostPosted: Wed Sep 27, 2017 3:22 pm
if you post a picture of your engine, we can point common stuff out so its easier for you.
There are no new unread posts for this topic. Spark Plugs...anti-seize or not?
nailbomb3
Fri Aug 14, 2015 9:40 pm
cjski View the latest post
There are no new unread posts for this topic. Spark Plug gap setting .050 or.060? - FIXED -
Drive-In
Sun Dec 07, 2008 9:13 pm
willwren View the latest post
There are no new unread posts for this topic. 1987 Bonneville No Spark, New ICM, New CrankPos.
cheporaiterei
23
4099
Fri Apr 13, 2012 12:18 pm
There are no new unread posts for this topic. Friend's '90 Bonneville has fuel/spark/no CEL-not starting
dandyd
20
3205
Tue Jan 22, 2013 2:29 pm
dandyd View the latest post
There are no new unread posts for this topic. Replacing rod bearing w/out removing engine
dandyd
Tue Jul 01, 2008 2:54 pm
