It is currently Sun Feb 17, 2019 7:38 am
PostPosted: Sun Sep 17, 2017 1:15 pm
Year and Trim: 1990 Bonneville Le
Hi new to club. I inherited a 1990 bonneville from MY grandparents who have past. Drove car from Tennessee to Illinois. Car then died. Have a code 42. Found that out after I pulled the dash and replaced ck engine bulb. I have replaced the icm tps camshaft sensor and crankshaft sensor. Hope crankshaft sensor is in right. Watched a lot of videos. Don't know where to go now. Would really like to keep car it's sentimental. Thanks in advance for the help.
PostPosted: Thu Sep 21, 2017 1:24 pm
Please anyone any help.Im at a loss on what to do.
PostPosted: Thu Sep 21, 2017 4:55 pm
It's not unheard of for the wiring leading to the crank sensor to get worn through and short out. Check out its harness for a couple feet. You'll probably destroy the loom in doing so, so have some handy.
PostPosted: Thu Sep 21, 2017 5:39 pm
Sorry didn't post that I already replaced the harness with a new one. This is driving me crazy lol
PostPosted: Thu Sep 21, 2017 6:26 pm
I'd suggest using loom from the engine compartment of a car at a wrecker. Any of the junk I've ever bought at parts stores has proven it's for interior use only and melted into a blob of plastic anywhere near the engine. I continue my quest for the "real" stuff (at a reasonable price).
PostPosted: Thu Sep 21, 2017 7:37 pm
I understand what you are saying and tend to agree bit the harness is brand new. Only ran car once. Does the crankshaft sensor have anything to do with this symptom?
PostPosted: Fri Sep 22, 2017 12:53 am
Will the car run if the throttle is held open? If so, how well does it run?
PostPosted: Fri Sep 22, 2017 10:36 am
It runs ok when I hold the pedal at a higher rpm.Sometimes it sputters a little but otherwise it's good. I drove the car from Tennessee to Illinois with no problems.
PostPosted: Fri Sep 22, 2017 7:24 pm
I know it's not related to code 42, but it may be good to check fuel pressure and behaviors to rule it out as a problem.
For 42, you may try checking the ground under the ICM. Sometimes I wonder if this code can set if the engine suffers from stalling and the ICM and ECM don't hand off to eachother properly.
Do you have a spare ECM kicking around?
PostPosted: Sat Sep 23, 2017 8:10 am
No don't have a extra ecm. And I already checked the ground. Don't know how much more I can change lol
PostPosted: Sun Sep 24, 2017 10:38 pm
If you or anyone has a run that's good let me know.
This topic is locked, you cannot edit posts or make further replies. 1990 Bonneville SSE Oil Cooler?
retroren
Thu Nov 13, 2014 8:59 am
J Wikoff View the latest post
There are no new unread posts for this topic. 1990-91 Bonneville Information.
Benvw99
14
2350
Fri Feb 13, 2015 4:47 pm
Benvw99 View the latest post
There are no new unread posts for this topic. 1990 Pontiac Bonneville GM Service Manual
72buickgs
Tue Jul 22, 2014 10:49 pm
72buickgs View the latest post
There are no new unread posts for this topic. IS 1989 Toronado Trofeo, 1990 Bonneville same air pump?
SSEBonne4evr
Fri Nov 30, 2012 12:04 pm
There are no new unread posts for this topic. '89 Bonneville stalls at Idle
Stephen
16
6597
Fri Mar 30, 2012 3:50 pm
murderedout View the latest post
