It is currently Tue Mar 19, 2019 2:42 pm
 Post subject: Maf issue???
PostPosted: Tue Jul 04, 2017 6:07 pm
Year and Trim: 90' Bonneville LE
So ive changed the battery, plugs, wires, and coil on my 90 bonneville. When i start it and let it run for a few minutes it will start to stumble and eventually stall out. Unpluggonf the maf allows the car to run at a bit higher than normal idle while in park. When in gear the car idles around 1000to 1200rpm. However it runs fine. Am i right in thinking my maf is bad? I tried to clean it and it didnt help nor hurt the issue.
 Post subject: Re: Maf issue???
PostPosted: Wed Jul 05, 2017 1:13 pm
hi, if the part is cheap, then I would replace the maf - did you check the wires and connection?
PostPosted: Wed Jul 05, 2017 3:13 pm
I did check them, all seems to be ok.
PostPosted: Wed Jul 05, 2017 5:34 pm
I'd say yes, replace - running well unplugged is a good indication that its wonky
There are no new unread posts for this topic. '89 Tachometer issue
ajla
Wed Nov 21, 2012 5:04 pm
ajla View the latest post
There are no new unread posts for this topic. Throttle body issue
Z-type
Mon Mar 02, 2009 2:24 pm
Z-type View the latest post
There are no new unread posts for this topic. is this a tranny or a govner issue or something else...help
88bonnsse
14
1689
Thu Feb 12, 2009 6:14 pm
Alibi View the latest post
There are no new unread posts for this topic. strange issue with '87 transmission
ad356
Tue Mar 29, 2011 1:05 pm
Jrs3800 View the latest post
There are no new unread posts for this topic. Stalling issue 1990
Karpov
41
3817
Tue Apr 15, 2014 5:19 pm
