It is currently Tue Jan 22, 2019 4:10 am
PostPosted: Sat Feb 11, 2017 12:20 pm
Year and Trim: '91 Olds 98 Regency Elite
'88 Bonneville
This car is old, has 308,000 miles on it. The drivers door lock has stopped working, by key and/or remote.... I pulled the cover off and it appears the plastic mechanism that houses the remote has broken somehow and is loose....it further appears this looseness is causes kind of a blocking of the rods. I'm assuming just replacing the mechanism.... BUT when I replace it, witll it automatically work with my remote??
PostPosted: Sat Feb 11, 2017 1:33 pm
hi, I would first try some high quality contact cement and see if it can be repaired and mechanism moves freely
PostPosted: Sat Feb 11, 2017 1:43 pm
'88 Bonneville
Also, the radio stays on when the door is opened and does not turn off like normal??
PostPosted: Sat Feb 11, 2017 2:33 pm
that loose module may get a signal from the door latch commanding the radio off. try to repair the loose thing and then move to radio-
that would be the logical progression if it were my issue...........good luck
PostPosted: Mon Feb 13, 2017 10:28 am
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
Do the dome lights turn on and off with the door being opened/closed? I'm not sure on the schematic for these, all my '86-'91 cars turn off with the key being taken out of the ignition, so not sure if the door sensor (located on the pillar) is a factor with the radio not turning off.
Runs:
Doesn't run:
PostPosted: Wed Mar 01, 2017 4:04 pm
'88 Bonneville
Lights don't even come in when driver door is opened......they do when the other doors are opened.
PostPosted: Mon Mar 06, 2017 2:23 pm
'05 STS-4
'97 LeSabre
That would mean that switch on the pillar is bad. I've never changed one, but I think you need access to the back side of it to pull it out.
Runs:
Doesn't run:
PostPosted: Fri Jun 23, 2017 8:11 am
Year and Trim: 1996 Buick Lesabre Custom - metallic dark cherry
I think ther is a way to disable the sensor in the door.. when I changed out the door on my 91 Cadillac deville my buddy disabled that. Then lights would not work with drivers door and closing the door meant radio stays on and turns off in 10 minutes unless you pull open another door.
Roads... Where we're going, we don't need roads
There are no new unread posts for this topic. A/C problem on a '92 Olds 98 Regency
dandyd
Wed Jun 25, 2008 9:17 am
dandyd View the latest post
There are no new unread posts for this topic. '92 Olds Regency Twilight Sentenel Problem
dandyd
Mon Oct 28, 2013 11:12 am
88bonnsse View the latest post
There are no new unread posts for this topic. '91 Olds Regency-- DOA Tranny or something else to look for?
dandyd
Wed Feb 01, 2012 11:44 pm
There are no new unread posts for this topic. '91 Olds Regency T-440 Transmission issue
dandyd
Wed May 26, 2010 4:56 pm
Jrs3800 View the latest post
There are no new unread posts for this topic. '91 Olds Regency Idle Issue.
dandyd
Wed Jun 30, 2010 9:07 am
