It is currently Tue Jan 22, 2019 4:19 am
PostPosted: Fri Jan 06, 2017 8:03 pm
Year and Trim: 1989 LE Bonneville
You guys have any suggetions about brand for a new thermostat?
It looks like the local NAPA and CarQuest have both the regular Stant and the Super Stant as their "store brands"
All O'Reilly's has in stock are "Murray Temperature Control Plus" and "Temp Control Ultra". Nobody local has a Delco in stock.
Thoughts?
Also, do I need to replace the O-ring on the water outlet in addition to using a new gasket for the thermostat itself?
PostPosted: Fri Jan 06, 2017 9:39 pm
hi, I always buy a fail safe stat so if it goes bad, it stays open
PostPosted: Fri Jan 06, 2017 9:57 pm
Sounds like they work from what I've read today. Also sounds like a lot of them fail quickly.
PostPosted: Fri Jun 23, 2017 8:05 am
Year and Trim: 1996 Buick Lesabre Custom - metallic dark cherry
Ive found that i have to change failsafe ones wver year or so. I order Super Stant and have no troubles with them
Roads... Where we're going, we don't need roads
PostPosted: Sun Jun 25, 2017 11:56 am
my safety stat popped for no good reason on me..replaced with the stant/napa brand. The good news is that these are the easiest thermostats to replace out of any car I've ever owned.
There are no new unread posts for this topic. Broke bolt removing it from thermostat housing
jimbone_sdca
Fri Mar 14, 2014 10:29 am
Zeik75 View the latest post
