It is currently Mon Feb 17, 2020 8:15 pm
PostPosted: Sat Nov 12, 2016 6:55 pm
Year and Trim: 1989 Oldsmobile 88 Royale Brougham Regency - FE3
89 Stalling at idle when stopping at intersections. Pulled code 34 - MAF. Cleaned the MAF as one of the 2 resistors was dirty. Still doing the same.
Is the MAF used in these vehicles only 89-91 or will one from a newer car work as well? My local junkyard only carries 93 and up cars.
1989 Oldsmobile 88 Royale Brougham Regency - Grey on Grey - FE3 - X06 Package - Limo Tint - Clarion HU - 2K Pontiac Grand Am 15" Alloy Rims
PostPosted: Sun Nov 13, 2016 12:31 am
Are you sure it's a code 34 MAF and not MAP? The MAP sensor rarely goes bad, but if you have an intake gasket leak, it could set it off.
http://straighttalkautomotive.com/OBD1/GM_OBD1.html
PostPosted: Sun Nov 13, 2016 3:13 am
No MAP, just MAF.
http://www.troublecodes.net/gm/88-90_38c/
You can usually confirm a broken MAF by tapping the sensor with the handle of a screwdriver. If the car stalls, it's dead for sure.
Rock auto suggests that the MAF is not interchangeable with the L27, only the LN3. However, it is looking like just the sensor is possibly shared with the LG7, which is the 3300 V6, which may also be worth a look.
PostPosted: Sun Nov 13, 2016 10:59 am
hi, you can try checking the wires from maf - look for damage
best to buy one thats specific to your ride............
http://www.ebay.com/sch/Sensors-for-Pon ... 539/i.html
PostPosted: Wed Nov 16, 2016 12:11 am
RJolly87 wrote:
No MAP, just MAF.
I unhooked the MAF connector and have been driving it for 3 days, no more stalling, only a very slight stutter when you take your foot off the accelerator sometimes at highway speeds.
Will look up which vehicles use the 3300 LG7 and pick one up in the junkyard if part numbers match.
PostPosted: Wed Nov 16, 2016 10:22 am
nice, keep the rpm below 2500 until you get new maf - buy one specific to your engine for less hastles
PostPosted: Sun Nov 27, 2016 12:00 pm
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
That particular MAF was only used from 1988-1991, according to ACDelco, Delphi and Rockauto.
Here are the vehicles that used it http://parts-catalog.acdelco.com/catalo ... ttype=5128
and Rockauto's applications list
Buyer's Guide :
ACDELCO 2133415 Mass Air Flow Sensor
BUICK ELECTRA 1988-1990
BUICK LESABRE 1988-1991
BUICK REATTA 1988-1990
BUICK RIVIERA 1988-1990
OLDSMOBILE 98 1988-1990
OLDSMOBILE DELTA 88 1988-1991
OLDSMOBILE TORONADO 1988-1990
PONTIAC BONNEVILLE 1988-1991
You can also look it up in Delphi's catalog http://partcat.com/delphi
PostPosted: Sun Nov 27, 2016 1:31 pm
Of course, part of the reason for so many different MAF numbers as well as things like Fuel pumps isn't the actual working part that makes it model specific, it's the housing it comes in. For example, I could have rewired the MAF and IAT which were seperate in my 98 Astro and used a 2001 MAF that integrated the IAT sensor into the MAF. The only difference was the plug. The MAF itself functioned the same as the previous years.
Now, I wouldn't necessarily try using a different manufacturers MAF in the car without doing proper research, but in reality, a MAF sensor isn't anything more than an airflow meter. It's a matter of how the auto manufacturer uses the data and how they spec the sensor. GM for the most part uses 12v, Ground, and a 5v sensor for most sensors that require voltage to operate ( O2 sensors, MAF, think along the lines of anything that needs to see a varying output ).
There are no new unread posts for this topic. 1989 idle humbs and 1500rpm hesitation
[ Go to pageGo to page: 1 ... 4, 5, 6 ]
Karpov
112
4724
Mon Jun 04, 2018 6:34 am
Karpov View the latest post
There are no new unread posts for this topic. 89' rough idle and stalling questions
danimal
Wed Jan 13, 2016 1:51 pm
There are no new unread posts for this topic. 1989 ABS
MattStrike
Fri Apr 26, 2013 8:15 am
There are no new unread posts for this topic. 1989 LeSabre LN3 MAF trouble...
turbokinetic
Sun Mar 29, 2015 6:55 pm
turbokinetic View the latest post
There are no new unread posts for this topic. Replacing the PCV valve on my 1989? What's the EASY way?
nailbomb3
Sun Feb 23, 2014 6:05 pm
pontiacsteve22 View the latest post
