It is currently Tue Jan 22, 2019 4:41 am
PostPosted: Sun Mar 13, 2016 4:50 pm
Year and Trim: 1990 SSE
Help :evil: I was feeling good having replaced the two front mounts and the right rear then I attempted to remove the left rear trans mount. I got it totally unbolted but I can not remove it. I read the service manual and it does not reference removing anything other than the mount itself. I carefully raised the engine and got more play but not enough. My next attempt will be to remove the steering link. I am close. Any help would be appreciated.
PostPosted: Mon Mar 14, 2016 7:20 pm
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Don't you just love helpful info like that?
Here's an old thread about this topic. Looks like unbolting the rack is what's needed.
PostPosted: Mon Mar 14, 2016 9:50 pm
I hope it's nothing like a '92 SSE. If it is you have to loosen everything the transmission and engine are bolted to (mounts and dog-bone) and "slide" the engine and transmission forward enough to "slip" the old mount out and the new mount in. IIRC, you have to undo the bolts holding your targeted mount from the transmission first - very tight fit for 1 bolt. I got compression fractures in 3 vertebra doing that (sliding the transmission and engine), so be careful, that is if it's like a '92. - BC
PostPosted: Mon Mar 14, 2016 11:30 pm
Thanks 1oldman and MKMike. MattStrike gave me the same advice as MKMike. Once I unbolted the rack and pried it upwards, I was able to get the mount out. Oh, I forgot to mention a lot of swearing went down too. I was glad to see a separation between the rubber and the metal on this pain-in-the-butt mount. I think the other three I replaced were probably still good but at least I got 4 new mounts. I hope after I tighten everything down and I do my test drive that I have a smooth shift from park to reverse without the clunk. I also painted and installed new front calipers along with black zinc drilled/slotted rotors and ceramic pads. I've got to break the rotor and pads in. I will be glad to stand upright after tomorrow.
PostPosted: Tue Mar 15, 2016 9:39 pm
I am happy to report the following was accomplished in the last week:
new alternator & serpentine belt
new set of ac delco platinum professional plugs
new drilled/slotted rotors with black calipers and ceramic pads for the front
all 4 engine/trans mounts (this was not fun)
replaced about a foot of fuel line that was cracking, not leaking (no more gas smell in the garage)
greased the front end
The best part is everything seems to working :) The sad part is the annoying clunk as I shift from park to reverse is still present. My '88 Toro did the same thing. I wonder if this just isn't normal for the '87-91 Bonnies. Oh well, I am not going to worry about it. Thanks for all that gave me motor/trans changing advice.
PostPosted: Wed Apr 06, 2016 11:18 am
Year and Trim: 99 Bonneville
Sounds good,
I don't remember any clunk in reverse of my 90 SSE.
Guess would be upper dog bone or exhaust knuckle near fire wall?
90 SSE Bonneville Sold but not forgotten.
There are no new unread posts for this topic. New guy looking for some advice 90' bonn
celliott83
Fri Jun 30, 2017 11:27 pm
celliott83 View the latest post
There are no new unread posts for this topic. Replacing rod bearing w/out removing engine
dandyd
Tue Jul 01, 2008 2:54 pm
dandyd View the latest post
There are no new unread posts for this topic. Broke bolt removing it from thermostat housing
jimbone_sdca
Fri Mar 14, 2014 10:29 am
Zeik75 View the latest post
There are no new unread posts for this topic. motor mount
boil359
24
3129
Sat Oct 09, 2010 11:01 pm
There are no new unread posts for this topic. Motor mount question
PocolocoBob
Wed Apr 03, 2013 8:55 pm
PocolocoBob View the latest post
