It is currently Tue Apr 16, 2024 2:13 am
PostPosted: Thu Jan 16, 2014 9:03 am
Year and Trim: 1989 LE Bonneville
Guys, I finally figured out where the dang thing is at on my VIN C Motor, thanks to a diagram from Autozone.
What's the EASIEST way to get the thing out as well as get out both the O-Rings to replace the whole shebang?
As you guys are aware its right UNDER 3 of the plug wires, and the vacuum hose that goes to the intake is rather short. I tried reaching down under the wires and trying to hook it with my finger (I have REALLY big hands) and just wound up giving up.
It's not just the plug wires either, the fuel rail is right over where it sits as well as some other wiring.
Help! :banghead:
PostPosted: Thu Jan 16, 2014 10:46 am
Year and Trim: '99 Montana
'92 Trofeo
I haven't done this job on a vin C motor yet (only it's vin 3 predecessor). But a combination of some smaller wood bocks, screwdriver, and a channel lock type wrench should be all you need to reach. The wood block is to give you something to pry against without chipping paint or whatever from the valve cover.
If you can, move things out of the way to make it easier to access. The old rubber grommet can be a pain to remove.
PostPosted: Thu Jan 16, 2014 6:18 pm
I'm pretty sure its in the same Location on the VIN 3? Back left hand side of engine underneath the fuel rail?
Are you using the screw driver to pry out the old grommets?
Thanks!
PostPosted: Mon Jan 20, 2014 12:18 am
I suspect I'm going to have to replace the hose as well, so what should I be using for that? I don't see it available as a part anywhere? What type of hose and does anyone know the OD/ID? Thanks :)
PostPosted: Mon Jan 20, 2014 3:00 am
'92 Trofeo
A rubber hose from the parts store will work, most likely 3/8" ID, or you can get a silicon hose.
PostPosted: Sun Feb 23, 2014 6:05 pm
Year and Trim: 1990 bonneville le
Last year I replaced my pcv valve after I had removed the intake for gaskets.I would recommend spraying some typs of lube like wd40 and slowly wiggle the thing out.Mine broke and the bottom half of the grommet went into the intake manifold. It takes 2 grometts so be very careful they get brittle with age.Hope that helps.
There are no new unread posts for this topic. 1989 ABS
MattStrike
Fri Apr 26, 2013 8:15 am
There are no new unread posts for this topic. 1989 LeSabre LN3 MAF trouble...
turbokinetic
Sun Mar 29, 2015 6:55 pm
turbokinetic View the latest post
There are no new unread posts for this topic. 1989 Bonnie caliper bolts
nailbomb3
Sun Apr 02, 2017 5:10 pm
rustyroger View the latest post
There are no new unread posts for this topic. 1989 front strut rebuild
Karpov
Thu Feb 28, 2019 12:32 pm
There are no new unread posts for this topic. 1989 Bonneville SSE engine problems
mbarcher
12
7175
Fri Jul 11, 2008 6:46 pm
mbarcher View the latest post
