It is currently Thu Feb 21, 2019 3:17 am
PostPosted: Thu Dec 19, 2013 5:42 pm
Year and Trim: 1991 Bonneville LE
1991 LE 145,000 new coil /ignition module/ plugs/wires/replaced water pump. no trouble codes stored in ecm. When car is cold starts right up and runs great. After 10-12 min the rpms become erratic and engine stalls and won't restart until temp falls off. Passed smog check last week and I can't figure it out.
Any help or suggestions would be appreciated[/color]
PostPosted: Thu Dec 19, 2013 8:12 pm
My first thought is the crank position sensor. Symptoms fit perfectly. The icm could be bad too, unless it did this with the old one too
PostPosted: Sat Dec 21, 2013 4:11 am
Year and Trim: 1988 LE
I would also say possible crank sensor, but the icm could be a likely culprit as well. I have learned the magnavox design overheats easily and will cause shorts within the bow causing exactly what you mention. Try changing to a newer ac delco 3 coil pack from a series 1 3800
-Austin-
yourgrandma wrote:
And thats how I got my mom pregnant.
There are no new unread posts for this topic. 89 Lesabre stalls when cold
moldymac
Fri Dec 06, 2013 9:31 am
SuperHbody View the latest post
There are no new unread posts for this topic. 91 sse cutting out when cold- runs fine warm!
pbgunrunner
Sun Dec 14, 2014 5:33 pm
pbgunrunner View the latest post
There are no new unread posts for this topic. 88 LE WONT START
88Royale
Wed Sep 24, 2014 10:30 pm
Zeik75 View the latest post
There are no new unread posts for this topic. car just wont start
pontiacsteve22
Sun Mar 24, 2013 3:02 pm
There are no new unread posts for this topic. Stalls sometimes when going from reverse to drive, ect
Chris D.
Thu Feb 24, 2011 9:30 pm
