It is currently Tue Sep 17, 2019 8:12 am
 Post subject: '90 SSE Hesitation
PostPosted: Tue Apr 02, 2013 4:48 pm
Year and Trim: '90 White SSE
NYC
OK - 267,000 miles
Having hesitation on normal acceleration and at times when cruising 60 - 75mph.
On heavy acceration - smooth going - no problem. MAF sensor was replaced 6 month ago when this issue first appeeared - seemed to take care of it - but it's back. No warning lights on dash... so no codes.
Shop tells me that there is a small coolant leak on intake manifold - but since so many miles - best not to mess with it - I keep an eye on coolant and top as needed.
Shop says they think hesitation is from deposits in upper head (?).
I'm no expert but couldn't this possibly come from the MAF sensor not good again or coil pack or blockage in muffler/cat system or vacuum leak somewhere? But, as I say, I'm just shooting in the dark...
I would appreciate any info or ideas - -
Thanks
 Post subject: Re: '90 SSE Hesitation
PostPosted: Wed Apr 03, 2013 8:48 am
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
Might be the sensor, but more likely to be a bad wire or plug or a weak coil. If the exhaust were restricted you would lose top end or if it's enough it won't even idle. I could also be a dirty or weak injector. Use an ohm meter to verify both ignition coil and injectors are good. If you've never done before, running a fuel cleaner (I like seafoam) may help clear up any blockages or restrictions in the injectors.
I would fix the coolant leak, you're wasting money in coolant by letting it leak out - which is a bad thing.
Runs:
Doesn't run:
PostPosted: Thu Apr 04, 2013 11:47 am
NYC
Thanks for the info Matt - I've had Seafoam coursing through it's veins for a couple of days - seems to be slightly better... but not gone - maybe it could use a week of Seafoam
Forgot to mention that if I'm accelerating hard - the shift from 3rd to overdrive at 60 - 65 bogs...
I'll have the garage check the coil, plugs, wires and injectors. Thanks again - much appreciated - and if anyone else has any thoughts - please feel free...
TP
PostPosted: Wed Apr 10, 2013 8:30 am
NYC
Well - Turned out to be spark plug wires - got them replaced and now - smoooooooth cruising in the '90 SSE!
Thanks for the info provided -
Tom
There are no new unread posts for this topic. 1989 idle humbs and 1500rpm hesitation
[ Go to pageGo to page: 1 ... 4, 5, 6 ]
Karpov
112
3916
Mon Jun 04, 2018 6:34 am
Karpov View the latest post
There are no new unread posts for this topic. 1991 Bonneville Runs Rough, Stalls, Hesitation
jmuse2482
Wed Dec 14, 2011 9:29 pm
jmuse2482 View the latest post
