It is currently Mon Feb 18, 2019 1:01 pm
 Post subject: car just wont start
PostPosted: Sun Mar 17, 2013 4:06 pm
Year and Trim: 1990 bonneville le
Hi curious why my 90 bonneville turns over and wont start? The mechanic said she had no spark and we need a new icm, i rplaced it myself and also put in a new coil both borg warner, there was a lot of goop around the bottom that happened before.The car ran but it still wanted to stall which was the original problem, on sat i unplugged the tps to check out what would happen, then i got in the car put her in reverse and she died and never re fired?? This is crazy she has fuel pressure and spark, need any advice folks, and thanks in advance :dontknow: also when you turn it over should the ses light come on and then go off.
 Post subject: Re: car just wont start
PostPosted: Sun Mar 17, 2013 4:51 pm
Is the SES light coming on at all? If it is, you should be able to pull codes out of it to see if that gives you any direction.
PostPosted: Mon Mar 18, 2013 12:32 am
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
Unplug the mass air flow sensor (MAS to the LG3 guys, MAF sensor for everyone else...) and try again. If it starts up and runs differently (better) than before, replace it.
The SES light comes on for a few seconds when you turn the key to on, it's the 'bulb check' iirc.
Did you put a 194 bulb in place of an injector to see if the computer is commanding injector pulse, or just check for full pressure at the rail? Both have to happen to have fuel in the cylinder.
Runs:
Doesn't run:
PostPosted: Mon Mar 18, 2013 4:10 am
Techinfo has a write up on checking the TPS. I guess if it fails in an open state (high output) it could disable the injectors thinking it is in a state to clear a flooded condition.
There is also a write up in techinfo for pulling the codes on these with a simple jumper made out of anything from a piece of wire to a paper clip.
I would link the articles, but I am on my phone right now.
PostPosted: Mon Mar 18, 2013 6:25 am
Year and Trim: Buick pa ultra 1991, 3800series I
i had similar symptoms- fault was a blown FUSE at right side relay center.
so check the fuses ALSO near the cars brain center (PCM).
sorry i´m from europe-expressions and understanding varies
PostPosted: Fri Mar 22, 2013 12:22 pm
First off THANKS 2 all of you who posted on this problem.It turned out to be a loose ground wire under the icm box, i could swear i torqued the nut down that grounds the computer under the icm, i found the inner nut loose????? What the heck all the stuff i did and one darn nut cause me grief, lol. This site is the bomb all of you are wonderful people, and remember to tighten and triple check everything, i can believe my dumb mistake :banghead: :banghead:
PostPosted: Sun Mar 24, 2013 3:02 pm
'05 STS-4
'97 LeSabre
Glad to see you got it figured out!
Runs:
Doesn't run:
There are no new unread posts for this topic. 88 LE WONT START
88Royale
Wed Sep 24, 2014 10:30 pm
Zeik75 View the latest post
There are no new unread posts for this topic. 91 LE stalls when warm and wont start until cold again
jimbone_sdca
Sat Dec 21, 2013 4:11 am
There are no new unread posts for this topic. '91 Olds Trany wont move until idling about 45 seconds.
dandyd
Sat Nov 09, 2013 1:08 am
There are no new unread posts for this topic. 1989 Bonneville SE back doors wont open
PontiacJake
Sun Dec 16, 2012 5:41 pm
There are no new unread posts for this topic. 1987 Bonnie LE was misfiring, now wont stay running?
Djkthegame
40
5447
Tue Sep 14, 2010 7:38 pm
Djkthegame View the latest post
