It is currently Sun Feb 17, 2019 8:17 pm
 Post subject: hard start in morning
PostPosted: Wed Jul 25, 2012 7:14 pm
Year and Trim: 1989 SSE Pontiac Bonneville
Please help. I have a 1989 Pontiac Bonneville SSE. I've been having issues with it starting in the morning lately; however the car usually starts after 3-5 attempts and runs fine for the rest of the day.
I have replaced the fuel pump and fuel regulator but the problem still persist. Any suggestions or tips PLEASE!!!!!
Thanks
Cook
PostPosted: Wed Jul 25, 2012 11:30 pm
Maybe the cam or crank sensors can do this? If I am remembering something I read a while back, the cam sensor is more important on pre-92's, is if it's bad (or the cma magnet is gone), it'll only start on average 1 out of every six times (because the PCM will guess where the cam is, and there are 6 cylinders), but it might be the crank sensor, and I am remembering it wrong.
PostPosted: Thu Jul 26, 2012 12:19 pm
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
+1 on the cam sensor.
Runs:
Doesn't run:
PostPosted: Thu Jul 26, 2012 8:31 pm
Thanks for the advice. I will check into it ASAP. It's been driving me nuts so this is a good place to start.
Thanks
Cook
PostPosted: Thu Jul 26, 2012 8:32 pm
Much appreciated. I will definitely give this a try.
PostPosted: Thu Jul 26, 2012 8:33 pm
Great Tip.....thanks for the quick response also.
PostPosted: Sat Jul 28, 2012 12:47 am
Year and Trim: 99 SSEi
A weak ignition coil can cause hard starting when cold. Check the resistance of all three coils on both the primary & secondary windings. Each set of three readings should be very close. If you have any that aren't close to the other two then this would be a good time to switch over to the Delco coils & ignition control module. There's an article on checking the coils & another on doing the swap in our Tech Info section.
2006 Chevy Monte Carlo SS
There are no new unread posts for this topic. Intermittent stall hard start need help trade BEER
theparkinggargae
16
1876
Fri Jul 30, 2010 9:08 pm
theparkinggargae View the latest post
There are no new unread posts for this topic. 88 SSE transmission shifts hard
Dudeski360
Mon Aug 01, 2011 5:31 pm
Dudeski360 View the latest post
There are no new unread posts for this topic. Hard to explain problem
EdroK
Thu Mar 19, 2009 4:17 pm
J Wikoff View the latest post
There are no new unread posts for this topic. 87 LE won't start
sandness
12
1549
Tue Oct 19, 2010 9:01 pm
horners87pa View the latest post
There are no new unread posts for this topic. 88 LE WONT START
88Royale
Wed Sep 24, 2014 10:30 pm
Zeik75 View the latest post
