It is currently Mon Jun 24, 2024 10:49 pm
PostPosted: Thu Jun 21, 2012 11:01 am
1990 Bonneville LE - Vibration in rear (seat vibrates) when braking above 40mph. Installed new rotors, calipers, drums, pads, shoes & 4 new tires. Still the same problem.
Any ideas what the problem might be?
[img]http://www.pontiacbonnevilleclub.com/gallery/albums/userpics/16137/1990_Pontiac_Bonneville_-_L_Side.JPG[/img]
PostPosted: Thu Jun 21, 2012 12:18 pm
Year and Trim: '99 Montana
'92 Trofeo
Could be a bad strut in the back, not providing any damping to the wheel, which would vibrate heavier under braking (it would still vibrate when driving, but may not be noticable).
PostPosted: Thu Jun 21, 2012 2:14 pm
Also check the tie rod ends and control arm bushings. A car this old will probably have some worn and bad suspension components and they all work together to control and stabilize the wheels. Yes, these cars have tie rod ends in the rear.
Put it up on some stands and take a good look for any loose or damaged components and then grab the wheel and try to move it up and down and side to side. There should not be any play when doing this and indicates a possible bad hub.
Also try swapping the wheels to the front and see if it moves. This would indicate a bad wheel / tire.
PostPosted: Thu Jun 21, 2012 4:53 pm
Thanks for the suggestions.
BTW, the car only has 67k miles. It runs well otherwise... even the A/C works. :)
PostPosted: Sat Jun 30, 2012 9:01 am
Year and Trim: 99 Bonneville
Check rear suspension and rear wheel cylinder & bearing bolts. Most likely in the wheel.
90 SSE Bonneville Sold but not forgotten.
There are no new unread posts for this topic. 1986 Fuel economy, power, braking...
MattStrike
Thu Nov 04, 2010 1:31 am
There are no new unread posts for this topic. Cv-joint vibration?
Karpov
17
1765
Mon Jun 02, 2014 4:27 pm
Karpov View the latest post
There are no new unread posts for this topic. Braking problem - pulls side to side
grant111
Mon Oct 28, 2013 9:26 am
grant111 View the latest post
There are no new unread posts for this topic. 1993 bonneville/trans sport alternator to 1990 bonneville?
Karpov
Fri Jun 28, 2019 2:10 pm
There are no new unread posts for this topic. 91 Bonneville Shaking
extrabigjon
16
4015
Fri Apr 27, 2012 3:20 pm
extrabigjon View the latest post
