It is currently Tue Apr 16, 2024 2:31 am
 Post subject: my A/C compressor
PostPosted: Sat Feb 26, 2011 7:42 pm
Year and Trim: 1990 pontiac bonneville sse
When i was driving my car for like 20 minutes earlier today i noticed smoke coming from my a/c compressor and then when later i went to start the car my belt snapped. Does anyone know are a/c compressors easy to fix yourself or do you need to have a mechanic do it and also can you just get it put on without charging the system with freon and just compressor oil? please help me i am trying to save money. thanks
 Post subject: Re: my A/C compressor
PostPosted: Sat Feb 26, 2011 8:31 pm
This section is for performance ADDING topics, not for mechanical problems. I'll move this to the proper mechanical section (87-91) for you.
PostPosted: Sat Feb 26, 2011 11:36 pm
Year and Trim: 96 SE
you will have to obtain another compressor. if you are going to change it yourself, you should first have an air conditioning shop or dealer evacuate the freon that is now in the system. your present system is configured to use R 12 freon. there are kits available at auto parts stores for converting to R 134A freon. once you have installed the new compressor, you will have to evacuate the air from the system before charging it. again, if you don't have the tools to do so, an AC shop can do it for you.
this post is just to familiarize you with some of the steps. it is actually quite an undertaking if you have never worked in this area before. it is possible to do it yourself. the club can help you.
if you have a shop or dealer do the entire job, probably count on $400 to $8oo depending on used, reconditioned or new compressor.
if you want to try it yourself, consider it a learning experience that will help with future AC problems.
PostPosted: Sun Feb 27, 2011 1:04 am
I'm not sure how the belts are on that setup, but you could either just bypass the A/C with a shorter belt, or remove the compressor and run an A/C delete pulley. Those would be your 2 cheapest options.
PostPosted: Wed Mar 02, 2011 9:25 am
IIRC the bypass is a 73" Belt
PostPosted: Wed Mar 02, 2011 8:06 pm
1987 Bonneville LE
i just within the past couple month posted a thread on doing a a/c bypass with pictures. i replaced my compressor with a bypass pulley and used the exact same belt and have had no issues with it since.
"CERTIFIED BONNIEHOLIC"
B I-1999 Bonneville SE -My First Bonnie- gone forever
B II-2000 Bonneville SSEi (black) 7/3/09 ZZpcm 1.0, Thrasher Cold Air Intake, Magnaflow hi-flow cat, 180 thermostat, Autolite 104's, solid hockey puck front mount, Intense 3.4 MPS. (OCT 2010 COTM Nominee)
B III-1987 Bonneville LE (burgundy) 7/22/10 -- Gone to Heaven
B IV-1991 Bonneville LE (black) 12/6/12 Parts Car -- Gone!
B V-1998 Bonneville SE (green) 9/11/13 -- 270,000+ and going strong! -- gone 287k+
B VI-1989 Bonneville SSE(gray)9/23/15
PostPosted: Wed Mar 02, 2011 8:07 pm
1987 Bonneville LE
viewtopic.php?f=20&t=23002
There are no new unread posts for this topic. ELC compressor location.
rustyroger
Tue Jun 13, 2017 3:15 am
rustyroger View the latest post
There are no new unread posts for this topic. 87 LE A/C Compressor Bypass
Djkthegame
Tue Jul 26, 2011 11:36 am
J Wikoff View the latest post
