It is currently Sat Jan 19, 2019 11:42 pm
PostPosted: Wed Nov 17, 2010 9:08 am
1987 Bonneville LE
The odometer stopped reading on my 87 LE, it is the gear driven odometer how do i fix this?
"CERTIFIED BONNIEHOLIC"
B I-1999 Bonneville SE -My First Bonnie- gone forever
B II-2000 Bonneville SSEi (black) 7/3/09 ZZpcm 1.0, Thrasher Cold Air Intake, Magnaflow hi-flow cat, 180 thermostat, Autolite 104's, solid hockey puck front mount, Intense 3.4 MPS. (OCT 2010 COTM Nominee)
B III-1987 Bonneville LE (burgundy) 7/22/10 -- Gone to Heaven
B IV-1991 Bonneville LE (black) 12/6/12 Parts Car -- Gone!
B V-1998 Bonneville SE (green) 9/11/13 -- 270,000+ and going strong! -- gone 287k+
B VI-1989 Bonneville SSE(gray)9/23/15
PostPosted: Wed Nov 17, 2010 12:16 pm
You need to dismantle the cluster. What likely has happened is that one of the gears has cracked on one of the digits. The way to fix it is to pull the cluster apart, and repair the cracked gear. The other possibility is if the motor for the odometer has gone out. In either case, as soon as the cluster comes apart, and the issue repaired, the odometer likely will show signs of tampering. That is a major red flag if you try and sell the car. Only other option will be to take it to a shop <I think it has to be dealership actually>, and have them correct the issue. What they will normally do is replace the odometer assembly, and document the mileage the service was performed not only in the system, but also in a sticker in the doorjamb.
There are no new unread posts for this topic. Speedometer/Odometer Stopped Working
89OldsRocket
Mon Jan 06, 2014 8:13 am
RJolly87 View the latest post
There are no new unread posts for this topic. '90 Bonneville Suddenly Stopped Running
bmgipson
Wed Sep 12, 2012 12:24 pm
There are no new unread posts for this topic. 91 Bonneville Shaking
extrabigjon
16
2603
Fri Apr 27, 2012 3:20 pm
extrabigjon View the latest post
There are no new unread posts for this topic. 91 Bonneville LE Questions
oddie121
26
5168
Sat Nov 09, 2013 4:25 pm
Zeik75 View the latest post
There are no new unread posts for this topic. 91 Bonneville Transmission Issues
Sat Jan 10, 2009 4:01 pm
