It is currently Sat Feb 16, 2019 3:58 pm
 Post subject: Intake manifold gasket
PostPosted: Fri May 14, 2010 8:00 pm
Year and Trim: 1989 LE
I need to change my intake gaskets asap.But Im having a problem with removing the throttle body. How do i remove the coolent tubes that go threw the throttle body?
157,000 miles Mods- polyurethane front endlinks,stb,180 thermostat,ceramic pads,225/60/15 Fuzion HRIs
PostPosted: Fri May 14, 2010 8:11 pm
They are just held in by o rings. Very carefully wiggle it while pulling. Just curious, why are you needing to change them?
PostPosted: Sat May 15, 2010 5:37 am
Year and Trim: 90 SSE
I know the tubes you are talking about as I just did mine. I found it very awkward to remove also. If you bought the felpro intake kit it has those o-rings to replace, you could try spraying a little carb cleaner into their seats which will help loosen those old o-rings up making them more plyable.
68 Chrysler 300 Convertible
68 Ford Mustang
90 Pontiac Bonneville SSE
98 GMC Yukon SLT
08 Mercury Milan Premier
PostPosted: Sat May 15, 2010 4:15 pm
Thanks guys for the Quick repys :banana: I'm changing them because they have not been changed yet and they are leaking pretty bad. I have to add oil and coolant at times.
There are no new unread posts for this topic. 89 SSE intake manifold gaskets/ turned into a crackedmanifol
yogidad
Wed Apr 22, 2015 5:10 pm
yogidad View the latest post
There are no new unread posts for this topic. No start manifold backfire
DarkestCon
Wed Aug 08, 2018 3:08 am
NoShowCar View the latest post
There are no new unread posts for this topic. OIL PAN GASKET REPLACEMENT
pontiacsteve22
Fri Sep 26, 2014 12:11 am
pontiacsteve22 View the latest post
