It is currently Tue Sep 18, 2018 11:52 am
PostPosted: Thu Jun 05, 2008 9:52 am
Year and Trim: 1989 SSE
Awhile back I had problems with a code 42 . Changed coil packs and spark sensor , crank sensor, egr valve , sparkplugs and wires and things worked well for awhile.
Now I have a problem with the engine backfiring and bogging out for the first mile then it seems to clear up . Also it seems to eat up the gas as it acts up , smells like it is flooding and in less then 30 miles have used a 1/4 tank of gas !
Any ideas as to what might be causing this problem ?
PostPosted: Thu Jun 05, 2008 10:30 am
Back fires are usually timing issues, so I would start looking there first. Though, if there's enough fuel being dumped into the system to flood it out, then the back-fire can be the excess fuel lighting off in the hot exhaust manifolds, and not caused by spark timing.
Do you have a scan tool that will show you the engines parameters while it is running? If so, start looking at the values for injector pulse width and the BLM's.. see if the ECM is creating the rich mixture in response to some other problem.
PostPosted: Thu Jun 05, 2008 6:34 pm
First, check for codes.
Second, how many miles? Typically, the timing chain on an LN3 should be changed out every 100-120k miles to ensure that it doesn't stretch too much. It would have to have a significant amount of miles on it before the timing was off enough to cause the problems that you are having (I'm thinking somewhere around 180k-200k miles).
If its not the timing chain, I'd say you may have a bad ECM.
-Eric
-1987 Fiero GT: 224k miles
PostPosted: Thu Jun 05, 2008 7:07 pm
Just a quick thought.... When you replaced the ECM, did you move the calibrator prom from the old ECM to the new one?
<added later: Disregard - I confused this thread with a seperate one from a person who changed out their ECM...sorry. >
PostPosted: Thu Jun 05, 2008 9:54 pm
I don't think he's replaced the ECM yet. I had an '89 Buick Park Avenue that did a very similar thing and it cleared up as soon as I replaced the ECM from another Vin C powered 3800.
I had these symptoms:
-burning VERY rich (black smoke out of the tail pipe)
-random codes, different every time I checked them via a paperclip... code 63 seemed to be the most consistent though
-randomly "bog down", IE run very rough or seem like it would idle down and want to die
A "new" ECM fixed all this. I got one from a local junkyard for $40 so they aren't horrible.
-Eric
PostPosted: Sat Jun 07, 2008 11:16 am
Yes I have changed out the ECM and put the old prom into the new (used)ECM .
The car has 172,000 kms on it , so that works out to around 105,000 miles
Seemed to work good for awhile then started up running rough and flooding out it seems . Figured it might be electric connections , but wiggled, unplugged, replugged etc and still nothing !
PostPosted: Sat Jun 07, 2008 3:42 pm
Where are you located? Its possible for the New used ECM to not be so good..
Is the Code 42 still present, and are there any other codes associated with the 42?
PostPosted: Sat Jun 07, 2008 3:53 pm
Year and Trim: ____
When you changed the coil packs, did you change the entire assy with the ICM?
John
PostPosted: Sat Jun 07, 2008 4:06 pm
X2 on this. Re-check for codes to see if anything else has been tripped since the last time you checked.
A few simple things: How old are the plugs and wires? When was the last time the fuel filter was changed?
100k miles shouldn't be enough to stretch the chain to the point of causing severe issues but keep in mind that it will need a new timing chain in the near future one way or another, but thats for a different issue for now.
-Eric
PostPosted: Sat Jun 07, 2008 10:19 pm
Yes .. both coil packs and icm were changed also installed "NEW" sparkplugs and wires
PostPosted: Sat Jun 07, 2008 10:21 pm
I'm located just outside of Winnipeg Manitoba.
As for the possibility that the ecm could be not so good , thats possible.
The code 42 has been only code I have found so far ...
Could the mass airflow sensor be causing this?
PostPosted: Sun Jun 08, 2008 3:26 pm
Yes the MAF could cause that but even then the majority of the time it will have a MAF code..
Disconnect the batter for a minute... Reconnect the battery and then do the code test without starting the car... Does the code 42 come back right away?
PostPosted: Fri Jul 11, 2008 6:46 pm
Ok seems the MAF sensor was part of the problem ... also the wiring to the MAF had a bad wire so rewired and everything runs good now .
Thanks for all the help and suggestions, very very much appreciated!
mbarcher.
There are no new unread posts for this topic. 1989 Lesabre "Service engine soon" light on.. check codes?
Chris D.
Sun Jan 23, 2011 7:28 pm
Chris D. View the latest post
There are no new unread posts for this topic. Motor/Transmission Swap from 1989 Bonneville LE
nathankinser
Tue Jan 17, 2017 7:09 pm
jradke61 View the latest post
There are no new unread posts for this topic. IS 1989 Toronado Trofeo, 1990 Bonneville same air pump?
SSEBonne4evr
Fri Nov 30, 2012 12:04 pm
There are no new unread posts for this topic. 1989 Bonneville SE back doors wont open
PontiacJake
Sun Dec 16, 2012 5:41 pm
There are no new unread posts for this topic. 1989 Bonneville SSE blower motor relay location question?
carguyblack
Mon Dec 03, 2012 7:09 pm
